cool weather hard start
Old 11-08-2017, 01:20 PM
goushyj24's Avatar
1998 24 valve started fine until last week. after start up engine idle was erratic but cleared up after a few minutes. temp dropped below 50 this week and now it runs for a minute and stalls. replaced lift pump and filter which were ok.bleed injectors and it will sputter and stop. any suggestions?
Old 11-08-2017, 03:52 PM
Midnite's Avatar
First thing I'd do is check for codes.
Do you have an aftermarket box installed? Like an Edge EZ or Comp? If so, disconnect it and see if the problem continues.
Old 11-08-2017, 07:10 PM
goushyj24's Avatar
truck is stock only code is for intake heater solnenoid
Old 11-13-2017, 03:21 PM
Midnite's Avatar
Well, if your intake heater isn't working, that could easily explain what's going on. Try replacing your solenoids--I bet that'll fix things.
I picked up my last set at Geno's Garage: http://www.genosgarage.com
joeel
12-06-2006 09:22 PM
jabber
11-07-2006 08:06 AM
chop342
07-26-2006 06:31 PM
dewclaw
07-23-2003 07:10 PM
Quick Reply: cool weather hard start
