-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Confused on torque specs (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/confused-torque-specs-330223/)
William Raab Apr 28, 2018 01:43 PM
Torque specs for dana 60f. I need the bearing cap torque specs. Going crazy trying to find.i get different views on lbs. For 2002 2500 diesel
Mexstan Apr 28, 2018 06:49 PM
Did a quick check on the 'net and found the following. Hope that it is of some help to you;
https://www.drivetrainspecialists.com/setup-specs
Dodge Ram Dana 60 Axle Specifications
Other sites I looked at appeared to all agree on 80 ft.lbs
Hope this helps.
