Codes P0236 and P0236
Codes P0234 and P0236
Is there anyone that can direct me to a diagnosis on these two codes. All of the searches are showing problems with modified engines and are not helpful with a stock engine. I would like to test, if possible, the sensor before replacing it to see if that solves it. Also, the derated fuel problem is very intermittent. I have tested the waste gate actuator with a vacuum and then verified movement with pressure and it appears normal.
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
