-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Codes? (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/codes-211508/)
kyncl Jul 18, 2008 12:35 PM
Codes?
:confused:How do you get the codes? Do you sequence the key a certain way? And when you do it.. what should it say if everything is normal? Thanks in advance.
TLDC Jul 18, 2008 08:35 PM
put the key in the ignition and turn it on and off three times (never starting the truck or turning it over) look where the odometer is that is where your codes will come up have pen and paper ready they go pretty fast. I believe they will start with the letter P and when it's done it reads done. Take care!
Old_Sparky Jul 18, 2008 10:24 PM
I have found a p1693 code in mine. Where can I find the OBD-II connector so that I can clear the code?
TLDC Jul 19, 2008 12:19 AM
I'm not sure where to find that but if you disconnect the battery for 15-30min. that should clear the code..........if it's fixed. Take care
cody_d Jul 20, 2008 02:46 AM
check this link out.
http://www.cumminsforum.com/forum/98...d-pcm-ecm.html
RacerRon Jul 20, 2008 06:38 AM
Not all codes will be cleared by disconnecting the battery. Some will require a scanner to clear. All ODB 2 connectors are within the passenger compartment within 2 feet of the steering column.
