Code troubles??
1765-trans voltage relay circuit either has an open circuit or a short
0753-shift solenoid A circuit electrical 1693-not to sure?? So either I have a short or a ground problem. That is what I am thinking. Does anyone have a clue of where I can get a wiring diagram for the electrical system. I also need to find what my voltage ranges need to be when the ignition is on and when running. If anyone has any ideas please let me know. Thanks |
Everyone has told me that the 1693 code is just a companion code that lets you know theres trouble.
Yeah thats what I keep hearing. I need to find the voltage for the tranny circuit so I can eliminate the guessing that my tranny is the prob which I know for a fact it is not the problem but I need to have all my ducks in a row when I take the PCM back to the dealer and request they replace because it is faulty. Just want to have all the proper paerwork so they can tell me no! I think it is a faulty PCM. I started having all these problems after I chaged the PCM. That is why I keep going back to the PCM is faulty. Thanks again ohio
[duhhh] Anyone???? Also the PCM was checked today and it turned up good after all, so I am back to the drawing board!
