Checking codes
Old Feb 7, 2007 | 05:56 PM
RAM2940's Avatar
Checking codes
When turning the key on/off method the only thing that i get is a P Done. Ive read on here that some are also getting codes from the ecu. Which comes back as a P ECU. Does the key trick check the ECU?
Old Feb 7, 2007 | 06:00 PM
sacnvr2l8's Avatar
thats what mine says with no codes...
Old Feb 8, 2007 | 10:41 AM
dssimecek's Avatar
With the key on off on off on mine check the PCM and if no problem will come up with p done. A few seconds later it will check the ECM, and if no problem come up with p done.
Just seeing "p done" is a good thing
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
DarrellB
Sep 6, 2003 04:49 PM
