changing wheel hubs
i have to change my wheel hubs on my 2500, is there anything special about doing this, and does anyone know where the best place to get them. thanks
Looks straight forward, only thing to know is the torque value is 280 Lb/Ft. on the retainer nut.
Actually looks pretty easy............ I like Rock Auto, if you have the time to order them in, otherwise Timkens at Autozone. |
is timkens individual bearings? mine is one unit
Nope, whole hub like you have. Actually from the picture, it looks like you could replace just the bearings, they are retained to the hub by snap rings, but I don't see any loose bearings for sale, just whole hubs.
https://www.rockauto.com/catalog/x,c...,parttype,1636 Looks like 192 each for Timkens at Rock. Actually, on edit, I found what appears to be just the bearings for 73 bucks at Rock, under the wheel bearing tab, at the bottom, Timken part # SET814 Depends on how long you can have the truck down, and how much potential hassle you want, hub assy's while more, will bolt right on. |
thanks patdaly, they've probably in there since the truck was new, maybe they won't be that bad
Shouldn't be bad at all, if you get the whole hub assy, literally it is remove the caliper, slide the rotor off, remove the big nut, slide off and reverse...............
There are 8 bolts that hold the bearing hub assembly to the rotor. Plus there is a tight fit between the hub flange and rotor, not press fit but with some rust it can be a challenge. According to service manual we're not suppose to reuse the hub nuts.
1 Attachment(s)
Originally Posted by bcbigfoot
(Post 3279230)
Attachment 44941 |
so is it bad to use the old nut, someone told me it's somewhere around 280 ft lbs of torque, would these be a dealer item
Maybe hard
Originally Posted by bigwayne
(Post 3279034)
ordered mine from rock,should be here anytime, i'll let you know, i guess i ain't got enough sense to take it to a shop, according to my wife
got the hubs, went to the dealer and ordered the nuts, they were castle nuts, the parts guy seemed to think they were right, turns out these things are teflon lock nuts, the castle nuts were $37 each, i can only wonder what the right ones will cost, does anyone know where i can get these teflon nuts
(Post 3279609)
See if he gave you 04746773. You need 2 ea. 06505007AA, list is $ 15.20 ea, moparpartsamerica has them for 10.92 ea, but by the time you screw around with shipping, it is probably as easy to get them from your dealer. |
what did you look under with mopar parts america can't seem to find them
(Post 3279687)
2002 - Dodge - Ram 2500 Base - - - L6 - 5.9L - DIESEL FRONT SUSPENSION / FRONT SUSPENSION / BRAKE COMPONENTS / Axle nut 6505007AA - Axle nut INDEPENDENT SUSPENSION, 2WD, 2000-02, 3/4 & 1 TON Left MSRP Core Online Price $15.20 $0.00 $10.92 |
