Changing Tranny Fluid
Old Apr 2, 2003 | 12:16 PM
drecu's Avatar
Hey guys i'm gonna be changing the tranny fluid either today or tomorrow on my truck &amp; was just wondering if you all had any hit's or suggestions? &amp; can I turn the line pressures up @ all on my 99?<br><br>DRecu!
Old Apr 2, 2003 | 03:51 PM
BigK's Avatar
Re:Changing Tranny Fluid
I did my '99 almost a year ago. Loosened the valve body bolts about 3 turns, and let drain overnight. Got about 11.5 qt out. You'll only get 6-7 w/o doing so. Re-torqued to (I think 13 #/ft, will check my manual), change filter, replace pan, start in neutral. Good to go. Measure qty of drained fluid, and you'll have a good starting point for refill.
Old Apr 3, 2003 | 08:36 PM
Farmboy's Avatar
If you are having any shifting problems, I'm usually not big on additives, but I've seen Trans-X (available almost anywhere) do some amazing things with Mopar Transmissions. I've used it and it really seems to help smooth out shifting and it may impress you if you are having minimal shifting shortcomings. It should be run for a while (20-30k) then replace with the ATF+3. I've even used it in 3-speed hydraulic shift transmission on a tractor and was astonished at the recovery of the middle gear (its all about the clutches and seals ;D).
Old Apr 4, 2003 | 06:05 AM
Commatoze's Avatar
I've heard of guys removing the line to the cooler, start the engine, and letting the pump drain the torque converter. Anyone familiar with doing this?
Old Apr 4, 2003 | 08:28 AM
bulabula's Avatar
Commatoze, I've done that before but never on a RAM. I've also done the same thing flushing power steering fluid too.<br><br>I think both methods (flushing and/or draining) have their advantages, but believe that flushing better removes the chunkies that may be found in the cooler &amp; lines before they made it into the filter that draining won't eliminate. <br><br>Draining can be done w/o help, but I've found it helps to have someone else around when flushing.
CTDowerTN
Nov 22, 2006 09:13 AM
Strick
Sep 11, 2005 07:52 PM
BigBlue
34
Apr 17, 2005 08:28 AM
mr T
Nov 1, 2004 10:50 AM
bkay
Apr 13, 2003 08:41 AM
