Transfer Case Fluid
Transfer Case Fluid
hey guys! i posted a thread awhile back about getting a list of all the things needed to be done at tune up time and someone mentioned to "change the transfer case fluid"
now i don't understand this statement. i've changed the transmission fluid before and i thougt the transfer case's fluid was just part of that or am i wrong? and if that's the case, how do you change the transfers case's fluid, and what fluid goes in it?
thanks folks
thanks folks
our transfer case has a drain plug on the backside (where the rear driveshaft exits) if you look on the lower portion of this casing you'll see 2 threaded plugs, i think they are 3/8 drive to remove. the lower drains the transfer case and the upper is to fill it. i like synthetic fluid and i think thats what dodge recommends
oh ok. so i guess you could compare it to a differential in the fact that the fluid just sits in there and is circulated by the rotating gears right?
and what weight do you use and is it specifcally labeled as "transfer case fluid" or is it just gear oil?
hey it's you again
ugh! i'm confused here. so you're supposed to put trans fluid in the transfer case, but yet it's seperate from the tranny??? this one just doesn't make sense. i suppose i just need to get under there and take a gander.
and then what is the capacity of this thing. do you just fill it to the top of the fill hole?
The t-case and tranny and complety sealed off from each other. Inside in the adapter housing is "dead space".
The tranny is pressurized(in some places) while the t-case is mostly just splash lube.
You are correct, just fill to the bottom of the fill plug just like a diff.
You dont have to use ATF +4. Any automatic transmission fluid will work just fine...
The additive packages in the Chrysler ATF are meant for their automatic transmissions.
Any automatic tranny fluid will work fine in that transfer case.
Funny how chrysler mandates a chrysler specific tranny fluid in a transfer case that is made by a spinoff company of GM (new process gear). NPG makes the transfer cases for Ford, GM and DCX...You think Ford and GM recommend Chrysler ATF in their transfer cases too???
Commatoze
16
09-23-2003 11:15 PM
