both front brakes started sticking today
today i droove out to a friends place to help him tow something and on the way back i stop and the truck seemed like it had a load on it taking off due to massive amounts of black smoke off the takeoff.. so i went home and jacked the truck up and both front tires i couldnt turn them and they were blistering hot i couldnt touch the rim even...... so i took the calipers off and i pushed them all the way in greased up the caliper a little and reinstalled the brakes cause they were pretty much only half worn... and the truck still does it.. it drags the front brakes lightly once u drive a few miles u hear them stop dragging probably from wearing down the pads tell it clears the drum.. but anyone have any ideas im not an brake expert...
oh ya i just wanted to add to it.. when you drive the truck it stops perfect no soft touch at all of the pedal.... also last few months before this happen the brakes would be very touchy when u first turn the truck on and when you droove down the road a little they would work perfect.....
My truck does this too. I'd also like to hear some opinions.
Brad |
Since no one else seems to want to respond I will give you one option. The problem is likely in the adjustment of the master cylinder. The piston is not returning far enough to allow the fluid to feed back and release the caliper.
Daniel |
Brad |
I am sure the master cylinder can be adjusted but I am not familiar with this particular one to tell you how.
Daniel |
When I said I was sure the master cylinder can be adjusted, I was referring to the push rod from the brake pedal. I was not able to confirm this in the service manual [service manuals are not what they once were].
This may sound silly, but have you tried pulling up on the brake pedal to see if the brakes will release. If your problem is between the master cylinder and the brake pedal, a new master cylinder will not fix it. Daniel |
I can pull "up" on the brake pedel with my foot and the brake will release. It's been doing it for a while now. I thought it was a sticking caliper. Anyone have any idea what I should look at to fix this.
Brad |
I can pull "up" on the brake pedal with my foot and the brake will release. It's been doing it for a while now. I thought it was a sticking caliper. Anyone have any idea what I should look at to fix this.
Brad Pulling up on the pedal would not effect a sticking caliper. The caliper is opened up by the friction of the disk. Daniel |
Thanks, I'll check it out.
Brad |
could it be the case if the pedal is not returning to the top that the return spring needs to be replaced? just a thought.
