-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Boost problems (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/boost-problems-313750/)
Nick Vannozzi Aug 12, 2013 05:37 PM
Boost problems
I drive a 1998.5 24v cummins, my boost gauge says I'm only putting out three to four psi of boost, is there any certain places to check for leaks? I don't think its the wastegate but let me know if I'm wrong!
Heimie Aug 14, 2013 03:43 PM
Check all your I/C boots. The lower ones can rub through on the inner fender and cut them. You should be able to hear a leak with high boost pressures. Add your signature so we know more about the truck and can help you easier.
