Blowby Bottle Removal
Old Oct 29, 2006 | 11:25 AM
GreatTruck2001's Avatar
Does removing the blowby bottle and extending the hose to an inch or so below the stabilizer bar cause any new issues -- like a mess somewhere else on the truck? Or, if I want to relocate the bottle, where is the best (easiest to clean) spot to put it?
Old Oct 29, 2006 | 07:22 PM
00' Quad Cab's Avatar
I extended mine straight down to about 3" past the sway bar, securing it to the sway bar.
Diff. cover is shiny but not coated with crap like the front of my motor and radiator were.
If you don't know you will need a 3/4" to 3/4" hose coupler and about 3' of hose to do this.
Some people run the hose back behind the transfer case or the front diff. but I just dropped it straight down as I always clean my undercarriage anyway.
O and most of us just ditch the bottle.
Old Oct 29, 2006 | 08:07 PM
jrs_dodge_diesel's Avatar
I ran the hose back to the transmission crossmember where the bottle sits. Been back there for about a year now and have had no issues with it. If oil is coating anything back there I haven't noticed it, but I really haven't looked hard in that area at all.
Old Oct 30, 2006 | 10:11 AM
Thanks to you both for the advice. I'm anxious to ditch the bottle and lessen opportunity for spillage!
Old Oct 30, 2006 | 10:41 AM
redstreak's Avatar
Make sure that when you extende the hose that you don't decrease the diameter - you want the flow to remain the same. You won't have a problem one with getting that blow-by further down to keep the mess off of your engine.
Old Oct 30, 2006 | 11:04 AM
4x4dually's Avatar
My bottle was removed for free by the dealer due to a TSB. I did however go back and etend the hose they put on it past everything I didn't want oil all over. Now it just comes out around the oil pan gasket so I gave up on a clean motor.
Old Oct 30, 2006 | 12:12 PM
Redstreak: do you consider using a barbed connector to attach the hose extension a restriction?
Old Oct 30, 2006 | 12:59 PM
redstreak's Avatar
I'd say not as long as it's not that big. I actually went higher up and cut the factory hose and got a bigger one to go over it but I'm sure your idea will work out great.
Old Oct 30, 2006 | 01:01 PM
4x4dually's Avatar
I also just slipped a larger diameter hose over the factory one. Why spend money on metal fittings?
Old Oct 30, 2006 | 02:49 PM
Mopar1973man's Avatar
I went a different route...
Old Oct 30, 2006 | 02:54 PM
4x4dually's Avatar
Dude, I respect your inginuity....buy I just couldn't open my hood to that! Maybe underneath, but not a-top that pretty cummins!
Maybe if you cleaned the primer off or painted it black of something.....
Old Oct 30, 2006 | 03:14 PM
redstreak's Avatar
That way would keep the crap off the bottom of the engine though - wouldn't that look cool if it was powder coated red or CHROME!!!!
Old Oct 30, 2006 | 06:22 PM
Ok... I showed the unpainted version for a reason but I did paint it...
You don't see it now do you???
Old Oct 31, 2006 | 08:38 AM
4x4dually's Avatar
Dude. MUCH BETTER! I like it now.
Old Oct 31, 2006 | 09:01 AM
The unpainted version you can clearly see the route I took to plumb the vent back. But as soon as I painted it flat black it dissappears fast don't it...
Ask BuckshotMcKee about his...
xxwildbillxx
Apr 21, 2009 05:04 PM
trik396
Jun 1, 2008 07:04 PM
sdsaw
Nov 1, 2006 06:53 AM
I SPEED
Dec 20, 2004 03:17 AM
Evildiesel
Oct 29, 2002 05:22 PM
