Beat The Chev Now I'm Knocking!!!
#61
Originally Posted by Lil Dog
Guys pushing 40+ Psi through a 12cm HX35 would probably see all of 300° and then some.
Rusty
#63
I wish I could afford it but the fella who is building my motor said the BD twins don't require you to go that far. He has ran them for a couple of years with only ARP studs and had no problems. He is well recognized around here and is a very knowledgable. The wife told me $10,000 and no more!!! She thinks getting married is more important than o-ringing and twins. I've already got away with the smarty, HRVP and the FASS.... Don't want to push my luck!
#64
When I was running my stock HY at stock boost levels with a BHAF and 4" straight pipe I saw a 500* difference at WOT. Normal driving and even cooling down they were always within 50-100* of each other.
#65
Finally got her back on the road, boy she purrs like a tiger... Sure is nice to drive a real truck! The egt's sure climb fast moving the probe to pre turbo. I'll have to keep a close eye on that untill the BD twins are installed. Sure won't push her to the limit again.
#66
The Guru
To make this build pay for itself and for the BD twins. Put in some decent sticks into that rig. Those jammer 2 are to small for those twins. I bought a set of BD155, no egt's issue and low smoke levels. Decent power, nothing big but a nice of daily drivers. Once you get those twins, I let you take the machers out for a burn. Running a HO pump and those twins you should be good. Your clutch might complain abit but what the heck its only money right.
#67
Hey Mike, do you work at that diesel performance shop near Sheppard Road??? Just curious.. I would love to take a ride in a twin truck before I put them on.. Did your twins cool your EGT's down and by how much???
#68
Thats good to hear that you back up and running
I have a set of my own twins but basically they are Piers towing twins(stock 35/14 and a Bht3b/26 from Piers) and I have DD2's and a drag comp and can spool the hell out of them. If I where you I would skip over the little BD twins and go for real sized ones (ie bottom turbo has a 5in outlet and is normally found on a class 8 truck)
#70
Well I could pass up 3k for twins cause I had the abilty to build my twins for around 1500-2k US never added it up and my buddy helped me out, and yes that is a Yrok A/C compressor that I will eventually be using as a air compressor. Oh and yess I know the paint looks crappy as I used high temp paint that needs to be cooked on in the oven and when I took them out it left finger prints from the welding cloves I had on
yes his truck is sweet looking but its not mine
#71
Please don't get me wrong there are lots of those BD twins out there making some killer HP but I think there are better/cheaper sets out there and if you want to keep chasing the big ##'s as far as HP goes the other sets are well adapteble to change
#72
This thread definitely makes more sense now
1300 pre turbo had me scared
Then saw it was post turbo and said wow, that makes more sense
I have heard between 300 and 500 deg difference. Either way, 1600-1800 is toasty.
#73
#74
Hi ya Dan, how's it going??? FASS is fantastic by the way.(13 psi idle-10 psi WOT) I was being a dumb*** and I learn't my lesson the hard way. All good now and runs very nice... The company that fixed it did a beautiful job for a pretty good price. Time for twins after I break it in..
#75
By the way, we don't really care what the duramax crowd thinks!!! The funny thing is, we own a duramax!!! The duramax I was racing is from around the Edmonton area and has 512 hp and 964 lbs. I think I did well, as I only have 380 hp... I didn't think I was cutting a duramax down, was just racing and ahead!!! My wife loves her duramax and I like my Cummins, go figure!!!
