-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Around 2000 rpm have sound like valves ticking....help (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/around-2000-rpm-have-sound-like-valves-ticking-help-20802/)
autodealer Dec 1, 2002 12:35 PM
I just got this truck it is a 2001 2wd Quad cab 5spd, the truck has 170k miles on it I picked it up cheap at the auto auction to pull a car hauler trailer with have no idea of previous history, but around 2000 rpm it sounds like the valves are ticking pretty bad, I don't actually know if it could be the valves or something in the turbo...anybody got any ideas, and I am new, so hello to everyone.....Thanks
Hired Gun Dec 1, 2002 02:08 PM
Re:Around 2000 rpm have sound like valves ticking....help
A friend of mine has the same situation. He said the wheel in the turbo had some play. He put on a new one, but still had a knock so a trucker told him it was the nature of the beast and to try automatic trans. fluid in a tank of fuel. He did and it quit knocking. I still think he needs to take it to a shop though. ???
Monty Dec 1, 2002 02:15 PM
Do not use ATF fluid as a fuel additive or conditioner. The detergent in ATF has been known to shorten the life of the pump and fuel lines, due to the detergent used in the fluid.
autodealer Dec 3, 2002 11:59 AM
Found what what the noise was, it wasn't valves, or the turbo, it was the tranny! Came out hauling a load home last night....anybody know the cheapest place to get remans?
patriot pearl blue Dec 3, 2002 05:28 PM
[quote author=OkieBroncRider link=board=4;threadid=7727;start=0#74191 date=1038773710]<br>Do not use ATF fluid as a fuel additive or conditioner. The detergent in ATF has been known to shorten the life of the pump and fuel lines, due to the detergent used in the fluid.<br>[/quote]<br><br> so how about using marvels mystery oil???
rich Dec 3, 2002 05:41 PM
You might try www.stdtrans.com there a place in florida that i saw that might be able to help you on a tranny
Monty Dec 4, 2002 04:46 PM
[quote author=patriot pearl blue link=board=4;threadid=7727;start=0#75163 date=1038958134]<br>[quote author=OkieBroncRider link=board=4;threadid=7727;start=0#74191 date=1038773710]<br>Do not use ATF fluid as a fuel additive or conditioner. The detergent in ATF has been known to shorten the life of the pump and fuel lines, due to the detergent used in the fluid.<br>[/quote]<br><br> so how about using marvels mystery oil???<br>[/quote]<br><br>Marvel Mystery Oil is fine.
