Anybody ran across this?
Old Oct 28, 2009 | 02:50 PM
oldwhite12v's Avatar
Went to do the lift pump on a 2001 today and was gonna do a direct replacement on the engine. Found a metal block in place of old LP and no LP to be seen on the frame rail. I'm assuming it must have been moved to the tank sometime in the past. Is the pump you get for the tank the same as the one on the engine? Bc I already have one of these. Just trying to figure out what I need before I drop the tank.
Also I was thinking of moving it to the frame rail this time, in that case does the old one need to come out of the tank or could it be left in there and just put another one on? Thanks.
Old Oct 28, 2009 | 03:05 PM
nkennedy's Avatar
The pump that's in the tank isn't the same as one that goes on the side of the block. Did you look on the frame rail for the lift pump?
Old Oct 28, 2009 | 03:27 PM
yeah, I looked up and down the frame, it's gotta be in the tank. Probably gonna put it on the frame this time for ease of replacement in the future.
Does anybody know if I could put it on the frame and leave the the dead one in the tank? Or would the old one restrict flow?
Old Oct 28, 2009 | 08:33 PM
Clunk's Avatar
I'd guess it'll have a hard time drawing fuel through a dead pump.
May have to plan a tank drop/bed lift.
Old Oct 28, 2009 | 08:41 PM
ClayBob's Avatar
Yup, You need to remove it. Problem is... its part of the module. So, you need to mod your module or replace with like. My suggestion? Get an Air Dog and be done with it forever (and now AD even has the already modded canister - a job many of us had to do for ourselves). 12-14 psi at idle and WOT. Good luck.....
Old Oct 29, 2009 | 06:59 PM
2500superram's Avatar
i left my in-tank pump there.i used a draw straw in the tank and external pump on the frame.
Old Oct 30, 2009 | 09:10 AM
patdaly's Avatar
If I had to do it again, this is the route I would go.
To the OP, welcome to the club, I have changed 2 back from the "better design". Vulcan performance is your friend........
madhat
Nov 25, 2011 09:57 AM
cbrahs
Apr 26, 2011 09:04 AM
glocklove
Sep 21, 2008 06:34 AM
