Antifreeze leak from head/Oil in rad
My '01 started leaking AF from the front of the head, just under the t-stat housing, definatly looks like its coming from the head gasket(nothing above that line) and there appears to be oil in the rad. I'm going to get VERY good at pulling heads. Is this a common place for the headgasket to leak? I don't suppose retorquing the head wouild fix it......
<sigh> Not gonna fool around, picking up a new gasket today and will install tommorrow. I just had the head off my '03 so atleast I have an idea how it goes.
Is the cylinder head bolt torque the same? 2 steps to 77ft/lbs and then 90* or is there an actual final torque spec?
4320Diesel
04-25-2011 09:50 PM
BC847
01-24-2008 08:30 AM
dodgediesel
09-23-2007 03:27 AM
