Are all Synthetic oils created equal?
Plugging in your truck doesn't heat the oil pan. Even running my ESPAR heater to get the engine to 70°C doesn't translate to the oil until you start and run the cold oil through the oil cooler, which is an oil heater for the first couple of minutes run time.
To each their own, but its up to the owner. I work with industrial machinery and have seen what different oils offer over the life of the engine.
Thanks for all the replies. I live in AK and the truck sits outside all winter. Our winter temps can run from the -20F's to above freezing. Most of the driving is to work, about 11miles, then come back home, about 11miles. I just bought this truck, 2000 Ram 2500 with 200,000mi. on it. The previous owner claims he used "long life" Amsoil and changed oil only every 15,000mi or so. I personally don't like that. I don't see myself driving anymore than 15,000mi a year at the most, so I was thinking of a twice a year plan spring and fall. Somewhere around 5,000 mi or 7,500mi oil change intervals. I guess another question I would also have is how do you tell if a oil is a full synthetic or not when it says it is a synthetic? What about switching between full synthetic and normal Dino oil, like synthetic for winter and Dino for summer? Anyways, thanks again for the help.
As for knowing if an oil is "man made" synthetic or not, you may just have to look up the oil brand on google and see if there's anything which indicates one way or the other. Thats not to say that any synthetic isn't better than regular oil either. Synthetic is superior on many levels but that doesn't mean its a necessity for what you want either. Sometimes its just a waste of money even though some guys will swear by what they use. So application and situation usually determine whats best. And also.....switching back and forth between synthetic and then regular oil is perfectly fine. Just dont even mix oil brands, types, or viscosities and you'll be fine.
I'm not trying to start an argument but I can't understand how synthetic is a waste of money unless I live in Siberia or Alaska. I live in the south and it gets a bit warm around here.
As far as cost, Amsoil synthetic plus Ea(25k mile) oil filter for my truck $126.05 off Amsoils website. Last oil change I went 14k. Basic rotella change every 3k. That's 4.5 oil changes -vs- the synthetic. What's a gallon of rotella go for? Honestly? I have no clue, $10? $12? Say $10, plus the $15 filter so you have $45 for one oil change. Seems low from what I remember spending on oil changes when I first got the truck.
For numbers sake though, $45 x 4.5 = $202.50, Amsoil saved me $76.45 on this oil change alone. The last oil change save me just as much. Now think of it from the greeny perspective, 14k and I dispose of 3 gallons of oil and one filter, 14k with rotella and I dispose of 13.5 gallons of oil and 4 filters? Not a green peace member but only seems logical. Some of you folks who use these trucks to putt back and forth to work 3-4 miles down the road with an occasional boat to the lake thing could go more miles on one oil change than I do making the savings even greater.
As I said, not starting some rotella, amsoil, purple power war just stating the basic economics that I have learned from using what I use and going by the fact that most guys I meet that run standard rotella still change their oil at 3000 miles or any standard oil for that matter.
But as you mentioned, I'm also not trying to argue because I too think that synthetic has its place and I use it myself in certain applications as well, but to say that its always better no matter the case.....I just dont agree.
5w40 rotella isnt true synthetic oil. Its a class III synthetic which is still petroleum based. Mobil1 is one of the few companies that have a true class IV synthetic oil. It's more expensive for a reason.
That being said, I run 15w40 rotella for my truck (break in) and will run 5w40 "synthetic" after break in.
There is no sensible way to argue whether synthetic is "worth it" or not-- this calls for a personal assessment of benefit, which is inherently subjective. So arguing over drain intervals, cost, worth it, etc is utterly pointless.
So let's instead focus on some consideration that are *not* subjective:
1) Synthetic base stocks are superior in everything a base stock is supposed to do. They have better high temperature oxidation resistance and better low temperature flow performance. Viscosity index for a synthetic base stock is almost always higher (a good thing).
2) Base stock is only half (arguably the less important half) of oil performance. The other half is the additive package. Whether a lubrizol or oronite or custom-in house additive blend, the kinds of additives used and the ratios of them can have a huge effect on overall oil performance and cost.
3) ALL oils (like tires) are compromises of often mutually-exclusive traits. You want an oil that stays clean and "lasts" a long time? Just cut back the detergent levels so that the crud stays in the engine. An oil with great wear performance tends to make deposits. A higher detergent oil doesn't protect as well. Higher TBN neutralizes more acid, but doesn't reduce weak acids caused by carboxylate formation (which tends to attack bearings and plug oil filters).
4) The best oil advice I've gotten from an oil expert here at Cummins was to change oil based on fuel consumed, not on mileage. The rate at which junk is dumped into the oil is correlated most strongly (almost perfectly) to the rate at which fuel is consumed. Then make this proportional to oil pan capacity.
It ends up being a "Gallons per gallon" ratio of fuel burned to oil pan capacity. A common benchmark is 200gallons of fuel burned per gallon of oil capacity.
Thus, if you have a 3 gallon oil pan capacity (round up the CTD's 11 qts since it can handle 12 safely), this would equate to 600 gallons of fuel consumed.
Depending on how you use your truck (your mpg), this could be as much as 12000 oil drain interval if you get 20mpg because you always do highway driving empty.
Now, you might think that 12000 miles is a long time for a B series to go on an oil change.
But scale that same 200gal/gal ratio up to an ISX and you'll see that it's not that long of a drain interval. An ISX holds 11 gallons. So the ratio tells us we'd be able to burn (11*200)= 2200 gallons of fuel on a drain interval. At 6mpg, this is 13,200 miles. If we are only getting 5mpg (say, heavy haul), then it drops to 11000 miles. The simplicity and effectiveness is beautiful.
The beauty of using the gallons of fuel consumed instead of mileage is that MPG is almost perfectly a proxy for duty cycle. Lots of cold start or stop and go driving kills fuel economy-- and automatically shortens drain interval using this method. Same thing with heavy towing vs running empty.
So remember that ratio: 200 gallons of fuel burned per gallon of oil pan capacity. It will serve you well in protecting your engine without wasting money throwing away oil that's fine.
Justin
Justin
One point to be made about longevity is what makes diesel engines happiest. And that is running a constant RPM over long periods. This is why long haul engines, locomotive engines, and generator engines last so long. Being around the trucking industry for decades, its amazing how long those engines will last. Even in short haul, guys will start their trucks in the beginning of the day and never shut them down until the day is over. Its all the start up/shut down and engines not reaching proper working temps which is the most destructive. As for oil.....I've seen old timers owner operators run their trucks on straight 30 weight which they buy bulk in 50 gallon. No big name brand, nothing special, just 30w, and their engines never miss a beat. That doesn't mean I condone that but its just an example. Lets not forget the thread of the guy with a 1.8 million mile ISB. He was a hotshot driver which means that truck always had a trailer hooked to it and kept its legs stretched out on the highway. Yes, he ran synthetic at 10,000 miles intervals but would he have gotten the same results on regular 15-40? Probably. Again, its all personal preference.
I know of a million mile plus ISB that changed oil every 30K with dino Delvac 1300. So absolutely the long highway miles are easiest on an engine.
My truck sees the most abuse imaginable-- cold start, hot rod 3miles to work, shut off. Repeat to go home. Repeat 5x weekly.
Because of this terrible duty cycle, I use Rotella T6 full syn, and no-- there's no cost justification for it at all. This engine would probably outlast the truck even with a lesser dino oil. But I'm doing what I can to ameliorate the operating conditions.
Yes, thats a good point to make. ONLY use any oil which is rated for diesel engines. And even at that, if you're bargain hunting for cheap no name oil then at least make sure it has SAE rating which meets or exceeds your engines year.
