ABS and parking brake light on
Old Dec 27, 2010 | 10:04 PM
cowboykilla235's Avatar
ok before you guys get on me TOO much.... buddy had his tocoma stuck in the snow on this hill, so i go out down this 5 mile dirt road (6 inches of snow, on top of a nice layer of ice) i pull him out and up the hill. so on the way back going down this huge hill i slide off into the ditch and got stuck. he gave me a lil tug from my reciever hitch (ya i know a tocoma pulled me out...) but after that my ABS light and my parking brake light was on. i mashed on the brakes and no anti-lock brakes... havnt check anything yet, was just wondering where to start.
vacuum lines?
speed sensor?
rear axle sensor...?
ABS comp module?
Old Dec 27, 2010 | 10:24 PM
torquefan's Avatar
I would look at the speed sensor on the rear differential. The connector probably either got broken off, or injested some water. You might also want to follow its wiring to the frame rail and forward, just to have a look for damage.
Old Dec 28, 2010 | 12:31 AM
archer's Avatar
sensor on the rear axle, i have the same truck and the same problem, $60 done.
Old Dec 28, 2010 | 07:49 AM
patdaly's Avatar
Yep, start simple, also, have AutoZone or another parts store who scans for free see if they can get the code ( some don't have the ability to read ABS )
It is probably something simple, sensor be it front or rear.....
Old Dec 28, 2010 | 08:51 AM
JVDodge's Avatar
If the sensor doesn't fix the problem, it may be the EBCM . I just went through this and the fix is to get the part from the dealer, remove the mounting screws for the EBCM (located on top of ABS pump), R&R new EBCM and you are good to go. $497....ouch. Literally a 15 min fix.....
Don't forget to remove battery terminals.........
Old Dec 28, 2010 | 11:23 AM
Ya I backed out and the pulled forward a foot and the pull strap tightened up, he said I bout near pulled his fillings out...I might have just jarred loose one of the sensors, that's gonna be the first thing I check. If I can't figure it out gonna go to the dealership, they charge $100 just to tell you what's wrong, and if its something stupid and simple as plugging back in a sensor thell do it for ya. Right now its 25 outside and there's 6" of snow on the ground,,, so kinda hard for me to WANT to go fix it right now...
Also why is my parking brake light on as well...?
Old Dec 28, 2010 | 11:44 AM
ok checked the rear sensor,,, couldnt find anything wrong with it, where is the front sensor at? remember this is an 02...
Old Dec 28, 2010 | 12:30 PM
i did a code scan on it myself with the ignition switch (P ecu and then P done) came up, and my light went off and my anti lock brakes are working great! any clue what those were?
Old Dec 28, 2010 | 01:41 PM
KATOOM's Avatar
Does your cruise work, speedo work, and do your brake lights work right?
Old Dec 28, 2010 | 01:44 PM
ya everything works great now! no problems like it was never there in the first place... does anyone know what PECU and PDONE mean?
Old Dec 30, 2010 | 04:07 PM
fschiola's Avatar
Not sure about PECU, however PDone always shows up when the scan is complete.
Old Jan 1, 2011 | 09:59 AM
dieselcamp's Avatar
I had the same lights on too and I replaced the ABS sensor in the diff and it repaired mine.
Old Jan 1, 2011 | 02:02 PM
scottsjeeprolet's Avatar
My lights come on every time i push snow. It has to do with all the excessive wheel slip in the snow/ mud.
It goes away and doesn't cause any permanent problems.
Don't worry about it.
Old Jan 1, 2011 | 10:04 PM
klineta89's Avatar
how do you do the scan with the key ive got the same lights on
Old Jan 2, 2011 | 08:13 AM
fschiola's Avatar
You turn the key on and off 3 times leaving it on the third time, but it will not read the ABS codes.
