abs/brake lights!
Old Feb 8, 2010 | 05:13 AM
02smokemaker's Avatar
abs/brake lights!
Ok I just replaced my vss on the rear axle and now My abs/brake lights stay on! Even after I reset ecm by unplugging batts for 30 mins. Any ideas thanks!
Old Feb 8, 2010 | 06:24 AM
Redtech1's Avatar
Speed sensor on rear axle. At least thats what it was on wifes 1500.
Old Feb 8, 2010 | 02:33 PM
Thats what I just replaced. Then lights came on.
Old Feb 8, 2010 | 02:42 PM
mishkaya's Avatar
Are you sure there are no issues with the connector? (corrosion, bare wires, etc...).
There is no reason for it to have come on just after the sensor change otherwise. Sorry I can't be of more help...
Old Feb 8, 2010 | 05:19 PM
nitrousn's Avatar
You need to get the ABS codes read.
Old Feb 10, 2010 | 05:33 PM
2500superram's Avatar
short on the wire's going to the wheel sensor's
Old Feb 12, 2010 | 08:10 PM
dozer12216's Avatar
Does the speedo work and odometer?? Correctlly???
If they are not working or light does not go out after several trips you may have other issues. A common area is wiring damaged near axle on left frame rail.
Old Feb 12, 2010 | 08:28 PM
jayjay's Avatar
Does it show any codes? with the key trick? Mines the same with a p0500, which is ''speed censor A'', the RWSS. My guess is a worn wire.
BuckyKatt
Feb 8, 2013 01:12 PM
quadstar
Nov 20, 2009 05:23 PM
polaris800sp
Nov 13, 2008 05:35 PM
kpmccarthy
Apr 23, 2008 07:42 AM
