99 2500 u-joint help
Old Jan 21, 2009 | 05:30 AM
smokinram99's Avatar
hi guys, ive checked my rear shaft u-joint, i wanna store 2 or 3 in case i need a replacement... I found this code on both T-CASE to RR SHAFT and RR SHAFT to RR DIFFERENTIAL: SPR (on one side) P9 CB (on the other side).
I cant find u-joints with that code...can guys help me? what joints my 99 needs? spicer or others are better?
FRONT SHAFT to FR DIFFERENTIAL has this code: SPR 509
thanks all for any help!
rob
Old Jan 21, 2009 | 10:33 PM
mini14's Avatar
www.rockauto.com
rear joints should take precision 330 u want nongreasable stick with the spicer, ive had greasables in for 6 years now no prob...the factory non's didnt last that long.
Old Jan 21, 2009 | 11:05 PM
torquefan's Avatar
The factory joints on the 99 are a Spicer, I believe the p/n is 5-801X. I don't think you'll find many others that will outlast it. Nothing else has a seal that will keep out as much moisture.
Old Jan 22, 2009 | 10:24 AM
mini14's Avatar
i know they have that triple lip seal bs, but still dont understand why they wear out so quick, imo spicer are a stronger joint if u get the cold forged ones but as far as outlasting id say no way. i grease them everyother oil change and they have lasted a lot longer then the spicers.
Old Jan 22, 2009 | 01:01 PM
thanks guys, so you raccomend me go w Spicer, exactly? stronger and better sealed? where I can find them? maybe the cold forged.
rob
Coaldigger
32
Dec 1, 2019 11:24 AM
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
