transfer case noise
Old 01-08-2010, 04:55 AM
x1phats10x's Avatar
Angry transfer case noise
well its been snowin here for a while now and on the way home for work i shifted into 4hi and i started to get a strange nosie plus when i got into OD my truck stared to buck really hard. Anyone have any ideas?? only thing i can think it is that the chain in the case is going bad. truck only has 129000 miles on it
Old 01-09-2010, 04:20 AM
x1phats10x's Avatar
guess no one knows
Old 01-09-2010, 10:52 AM
nickg's Avatar
before blaming TC, inspect frt drv shaft u-joints and double cardan joint, dont forget to inspect front u-joints...almost always 4x4 noise vibration is a failed joint in the driveline
Old 01-09-2010, 10:55 AM
nickg's Avatar
i see you have an 02, do you have CAD (vacuum locking front diff) or the newer 03 and up front diff (front wheels locked in all the time)
Old 01-09-2010, 10:47 PM
x1phats10x's Avatar
front drive shaft has all new joints and the front end dosnt have the vacuum acuator
Old 01-10-2010, 01:13 AM
nickg's Avatar
Have you checked the front joints as well? I've changed lots of them on 3rd gens, you'd think with the front end turning all the time the noise/vib would show in 2wd, but it only rears its head in 4wd, I've also seen them pile up so that they appear tight, when infact they are not, usually you will see rust colored dust near one or 2 of the u-joint caps..
and speaking of needing to replace u-joints I gotta replace another pass side joint 3rd one in 3yrs, it has play and rust near one cap, drv side has 473,000kms on it and its orginal (non greaseable) all the pass side joints were greasable precision joints...go fiqure
Old 01-10-2010, 08:54 AM
dozer12216's Avatar
Were you driving on a relative good traction surface?
Sort of gatered you were. If the rolling diameter of tires are not the same it will bind up the driveline and make similiar noise.
Even if tires the same the drive line will bind up from going around curves. Rear wheel path is less than front in curve.
Only drive in lock when tires can easilly slip as on ice or off pavement.
And then you could have a streched chain from previous above mentioned events.
Old 01-10-2010, 08:28 PM
x1phats10x's Avatar
it dose on in slick condions and non slick condions im thinking its the chain because of the bucking around
Old 01-10-2010, 08:30 PM
nickg's Avatar
not sure about these TC but most when the chain is worn that bad, if you load it up in gear with the brakes on it will skip/grind.
or maybe front diff is going and thats causing a binding/buck
wyododge
08-18-2011 07:48 AM
SHARPMACHINE
13
01-12-2007 07:39 AM
Jambbii
12-04-2005 10:55 PM
FRANKV469
12-16-2003 07:33 PM
Quick Reply: transfer case noise
