47rh won't go into OD - Dodge Diesel - Diesel Truck Resource Forums
Old 01-11-2018, 02:34 PM
greasy's Avatar
I have a possible vacuum leak, I notice it in my brakes not assisting if the engine is idling and I use them a few times. Would that cause it?
What other possible culprits should I check?
greasy is offline
Old 01-11-2018, 02:37 PM
greasy's Avatar
opps sorry I got this in the wrong forum section
greasy is offline
Old 01-11-2018, 02:53 PM
Your title doesn't match your post? A weak pump or bad hoses will cause a low vacuum issue. Have you recently been under your hood for something else?
deere country is offline
Old 01-11-2018, 10:35 PM
greasy's Avatar
I was asking if weak vacuum will cause the transmission to not go into OD, and what other things should I check as a possible cause for the TC to not lock up in OD. It just stays in 3rd gear.
greasy is offline
Old 01-12-2018, 01:05 PM
cougar's Avatar
OD and lock up are purely electric. Power is supplied to the center wire on the three wire plug on the transmission. The PCM provides the ground for each solenoid. Possible problems include a bad PCM, a bad OD solenoid, a bad OD to PCM wire, or maybe a bad TPS. Could also be an internal transmission problem. I'd start by manually grounding the solenoid wire and see if that engages OD.
cougar is online now
The Following User Says Thank You to cougar For This Useful Post:
nothingbutdarts (01-12-2018)
Old 01-12-2018, 04:10 PM
AlpineRAM's Avatar
I'd start by checking for voltage on the center pin when the ignition is on.
('cause I am lazy)
AlpineRAM is offline
Old 01-12-2018, 08:44 PM
greasy's Avatar
Ok thanks guys
greasy is offline
Old 01-13-2018, 11:20 AM
cougar's Avatar
('cause I am lazy)
Sense he didn't say lock up wasn't working, then I figured he has power to the solenoids.
Old 01-15-2018, 07:48 AM
AlpineRAM's Avatar
@cougar
Looks like no OD and no lockup to me.
Old 04-04-2018, 12:21 AM
greasy's Avatar
I have lock up in 3rd, but no OD. If I push the tow haul button I get TC lock.
greasy is offline
Old 04-04-2018, 07:18 AM
AlpineRAM's Avatar
OK, now you need to find out if the lack of OD is caused by the PCM not signalling for OD or the transmission ignoring the command.
You can do that by wiring a small (2-3W) bulb in parallel to the OD solenoid, so that you can watch the lamp while driving.
(I usually make a jumper cable with a male and a female plug that fits between the transmission and the plug coming from the vehicle. The bulb wires are zip-tied to the frame and come in through the driver side door. I use a green and a yellow bulb from a motorcycle .neutral and turn indicators)
If the light comes on and no OD- something wrong with the solenoid, or the hydraulics in the valvebody, or maybe even a worn out OD clutch piston seal.
No light- Try again with the alternator deactivated by removing and insulating the small red wire, because sometimes the reason is too much electrical noise.
If this fixes it, get new brushes for the alternator.
cougar
04-07-2018 09:03 PM
freds40
10-22-2011 04:26 PM
90firstgen
12-15-2009 06:11 PM
Firstgenner
09-30-2006 01:57 PM
Nicholas
12-24-2002 07:02 AM
Quick Reply: 47rh won't go into OD
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
