241 HD TransferCASE Question
Old Feb 11, 2008 | 03:07 PM
Sunir's Avatar
I always thought (was told by folks etc...) that dually's and Manual 2500's had the NP241 DHD case w/ 29 spline shaft as well as Dana 80 out back
while Auto 2500's had the NP241 DLD case with the Dana 70 out back
Is this not correct?
Old Feb 11, 2008 | 03:13 PM
Southern Pride's Avatar
Sunir,i was wondering the same thing as well. im bout to start on my auto to nv4500 swap, and ive got a 02 1 ton dually. i gess ill check it when i get home.
Old Feb 11, 2008 | 03:15 PM
bnold's Avatar
Mine is HD
Old Feb 11, 2008 | 03:48 PM
SIXSLUG's Avatar
My build sheet states that my truck has the camper package and tow package, heavy duty service group, and upgrade front springs but no Plow prep package. The 241 HD transfer case is listed but the tag on the case itself reads 241HDH.
Old Feb 11, 2008 | 06:52 PM
jshaw214's Avatar
Originally Posted by torquefan
I've actually noticed that the majority of 2500 trucks have just the 241LD.
Yup, 241 DLD right here and I broke it boost launching so I am going to the NP271. The HD is not common it is an option.
Old Feb 11, 2008 | 07:20 PM
Russ Roth's Avatar
My buddies '99 and my '01 are pretty much equipped the same except for the Transfer case. He has the HD one and I have the LD one. Both auto trans.
Old Feb 12, 2008 | 08:20 AM
checked last night, and my t-case says HDH on the tag. im assuming thats the heavy duty one? my truck's gotta auto in it, guess thats what i was confused for. i thought that auto's had the LD one. oh well, that helps me out cause all i gotta do is get the right drive shafts.
Old Feb 12, 2008 | 10:59 AM
tha89sx's Avatar
tow and heavy service group 2500 auto dana 70u and i have the hd241
Old Feb 12, 2008 | 01:31 PM
smokinram99's Avatar
also on mine: 2500 SRW AUTO DANA70 241DHD
Old Feb 12, 2008 | 02:54 PM
Tractor Truck's Avatar
I have the 241 DHD. Auto
Old Feb 12, 2008 | 10:09 PM
rattlerbob5.9's Avatar
The heavy duty t-case was optional on the 2500 trucks with an automatic for example in 1996 it was $100 more . It can be identified by the new process tag bolted to the rear of the case like they all are. The tag is aluminum and red about 2.5 inches in diameter it will list the model number as well as the gear ratio. The 241 dhd t-case can also be identified by the bolt on stamped steel pto cover on the passenger side of the case. If you do not have the steel plate then you have a 241dld t-case.
Old Feb 13, 2008 | 09:05 PM
Bjans's Avatar
are they a direct replacement for each other? What i mean is can you take out a dld aand bolt up a dhd with no other mods?
Hodge
21
Sep 13, 2019 09:49 AM
ram 2500
Dec 8, 2008 08:07 AM
ram 2500
Dec 7, 2008 12:45 PM
evan4434
0
Dec 6, 2007 11:59 AM
jpfishmaster
14
Aug 12, 2006 03:28 PM
