2002 Auto Trans Jumping Under load?
I have the Auto crapper, while pulling the boat it has started really jumping and shuddering under load if I let off the go pedal it stops, if I ease back onto the throttle it normally wont do it. I also noticed if I turned up the juice to 4 and get on it, it will do the same thing without a trailer? Torque converter?
No enough info to really help you.
Is it doing this in 3rd or OD? Can you tell if it is the converter clutch unlocking? Do a search on converter unlocking or maybe shudder, and even electrical noise. |
its not hunting between lockup if that's what your thinking, it shakes the whole truck pretty hard, as far as noise all I hear is the stuff in the cab rattling and jumping around. It seems like its between third and forth.
Sounds like you have had all the fun a stock tranny can deliver behind a modded engine. Remember more horsepower equals less reliability.
probably true.
