2001 dodge ram 2500 won't start
The park/neutral position switch??? isnt making contact with the nub in park...upper right corner
#2 wont contact #1
We can't get them to make contact with each other...how can I adjust them....is it possible
It should start in both Park and Neutral. If it starts in only one of those positions, adjustment is needed. If it starts in any other position (like reverse or drive), or not at all, then the switch may be faulty.
I would put an ohmmeter on the switch terminals first and make sure it's opening and closing like it's supposed to.
Hope this helps
Check condition of the shift linkage. Do not attempt adjustment if any component is loose, worn, or bent. Replace any suspect components. Replace the grommet securing the shift rod or torque rod in place if either rod was removed from the grommet. Remove the old grommet as necessary and use suitable pliers to install the new grommet.
(1) Shift transmission into PARK.
(2) Raise and support vehicle.
(3) Loosen lock bolt in front shift rod adjusting swivel.
(4) Ensure that the shift rod slides freely in the swivel. Lube rod and swivel as necessary.
(5) Move transmission shift lever fully rearward to the Park detent.
(6) Center adjusting swivel on shift rod.
(7) Tighten swivel lock bolt to 10 N·m (90 in. lbs.).
(8) Lower vehicle and verify proper adjustment.
nothingbutdarts (08-01-2016)
