2000 CTD fuel MPG
Just like to hear some input on increaseing my mpg on this truck,I tow RV's and need to boost my mpg on my dead heading home,I removed muffler and res. and put in a Amsoil air filter,2000 4x4,2500 series 410 gear,auto trans,stock,not really looking for HP just 2-3 mpg would be nice.
Re:2000 CTD fuel MPG
Even though you are not looking for horsepower, some have gained mpg with a fueling box, such as an Edge EZ or the like. Personally, I gained maybe 1/2 mpg while towing, but the smile alone is worth it. ;D
After all the changes I did I get 22.5 empty and 17.5 towing a 6000lb trailer. I did notice a drop in the last couple weeks so my guess is the local stations have changed to winter blend
Going to 235/85/16's will get you one extra mpg.
[quote author=induchman link=board=4;threadid=22174;start=0#msg209676 date=1068840159]
Going to 235/85/16's will get you one extra mpg. [/quote] Good advice. Anything you can do to lower wind resistance or rolling resistance is going to help.. Use the smallest tires that will carry your load adequately ( the 235/85r16 is a good recommendation). Try a tire like the commercial grade ones from BFG and Michelin (XPS rib or XPS traction). Decreasing the ride height of the truck will lower wind resistance. Usually, the 275 injectors improve mpg and add about 40hp. The RV injectors are the ONLY engine mod I know of that USUALLY increases MPG. The rest may or may not--it's a crap shoot. Justin |
Dave
I punched some holes in my air box (8) and it bumped up the mpg by in town but i didn't like the add noise.I am getting an air box after market type . |
that was 2 mpg
jigdog how much extra noise did the holes cause
torg
i don't know how to judge it very well but i didn't like it and neither did the wife. ;) |
