1999 Up-shift/down-shift problem
Old Mar 14, 2010 | 08:13 PM
hangerbum's Avatar
A 1999, Ram 2500, 5.9, 4x2, 4-speed auto. At a steady 45 mph, the transmission up-shifts and down-shifts changing the rpm’s about 300 rpm between shifts. What really makes the problem difficult to diagnose is that it is intermittent. It will exist for days at a time then disappear for weeks. Replaced the BWD speed sensor but that did not solve the problem. Any advice is appreciated!
Old Mar 14, 2010 | 10:36 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Yep, this sounds like one of the most common issues with these VP trucks. Clean all of your battery terminals and the ground contact areas. Then also do an APPS reset. If the problem still continues, insulate (with tin foil) the ground wire that goes from the passenger side battery to the motor.
Old Mar 15, 2010 | 10:07 AM
hangerbum's Avatar
Thanks! Sounds a lot simpler and less expensive than the other possibilities I was imagining....
Old Mar 15, 2010 | 11:22 AM
j-fox's Avatar
Most likely this is the converter clutch locking/unlocking. Electrical noise in the system.
As said, clean battery posts and check grounds.
I use the DTT noise filter.
After several years it returned and I tried everything. Then laying under it I found the passenger battery ground at the block was finger tight. Snugged it down and it is good again.
Old Mar 15, 2010 | 07:05 PM
samaf's Avatar
My truck did the same thing. There is a large wire connection under the fuel filter, took this apart and cleaned it with contact cleaner and this helped my problem. Also wrapped the ground wire with tinfoil. Trans shop found a wire broken in the trans wire bundle between the firewall and the tranny. After all this no more problems. Just some things to look at. LOL
lonny1965
Mar 26, 2008 09:01 PM
nelly
15
Mar 12, 2008 11:42 AM
pupeperson
Jul 17, 2007 12:29 AM
poogan
May 4, 2007 08:47 PM
wrm
Jan 5, 2007 05:15 PM
