Is it 100% the TPS
Old 12-25-2012, 10:01 AM
OneHigh4x4's Avatar
Is it 100% the TPS
Over the last 6 months the truck has been surging. Set the cruise and it goes away. Finally quit completely the other day. Truck would idle but as soon as I gave it throttle in any gear over 1st lost all power. CEL came on. Ran it by autozone and the code was for the throttle body sensor. Finally it started running again, with surging, but managed to get it home. Ordered my timbo apps but before it got here I ran the truck down the road to test again. Not only did it run normal but the CEL went off. Would I be correct if i said the TPS is still on its way out and I should go ahead and change it out?
Old 12-25-2012, 03:19 PM
SIXSLUG's Avatar
If it is your APPS (Accelerator Pedal Position Sensor) it will do what you described when you activate your cruise.
The Timbo will fix the surge/miss and will smooth it out.
As for the CEL coming on, I am assuming that showed up on the overhead display.
You are talking about the 01 3500, correct?
Old 12-25-2012, 03:27 PM
Homestead's Avatar
Your cruise is electronic, if the surge goes away while cruise in engaged, APPS is on the way out, simple as that.
Jeff
Old 12-25-2012, 03:32 PM
OneHigh4x4's Avatar
Yes its the 01 3500. Surge always goes away with cruise. Just thought it was odd it would completely die and then come back to life a few minutes later and then the next day turn the CEL off by itself (the one on the dash). Guess I will throw the new apps on there and maybe it will be fixed for good.
Old 01-03-2013, 06:36 AM
pwregan's Avatar
timbo apps
Was your truck smoking while it was surging and loosing power?
Mine has the same symptoms you describe plus a lot of smoke when i press the pedal down.
I have a new tps from timbo-wanted a warmer day to install it- just my luck- first cold snap and all goes to hell
Old 01-07-2013, 01:57 PM
pwregan's Avatar
Timbo apps
I just finished my install and wanted to say- great product and excellent instructions!!- thank you for one stop shopping, right down to the paper clip.
Unfortunatly it did not cure my stumbling engine problem.
engine stumbling and smoking with pedal pressure- i think my vp44 is gone or my injector or injectors- calling a professional in the morning
Old 05-02-2015, 07:40 AM
Marine's Avatar
pwregan, what did you find out?
I know it is an old thread, but a friend of mine is having the same issue.
Thanks!
whosdunit
05-17-2014 08:54 AM
53 willys
38
11-06-2008 11:18 AM
Davidp
02-01-2003 05:49 AM
16
11-29-2002 11:53 AM
harrisg
14
11-14-2002 09:05 PM
Quick Reply: Is it 100% the TPS
