-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   02 keeps losing/unable to build power (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/02-keeps-losing-unable-build-power-19477/)
tonyjsan Oct 28, 2002 09:37 PM
HELP !<br><br>I have a 2002 2500 Dodge quad cab long bed p/u with the cummins standard diseal and 5-speed manual. The truck has about 11,800 miles and ran great until begining of Oct. I use for work and pulling a travel trailer (light about 8000 lbs fully loaded).<br><br>The truck started to surge (depress the accelerator pedal and no response, then power somtimes begins to buid) / loose power and the check engine light would come on. I have had the truck to the dealer 4 times this month (it's been in repair every week in Oct). The dealer has replace a turbo boost sensor and on the last visit a wire harness of some sort. After the wire harness replace it worked for about 3 days and messed up again.<br><br>I have contacte the Dodge tech support in detroite talked to the dealer owner .....,<br><br>HELP ! Has anyone run into this have any ideas, the dealer seems to be unable to resolve the issue.<br><br>Thanks,<br><br>
Oct 28, 2002 09:42 PM
Re:02 keeps losing/unable to build power
Tony, I would look at the MAP and IAT sensors real close, check all the connections and if you can, pull them and check to see how clean they are. Second pull the fuel filter and replace it, if it has not been done already. It really sounds like an electrical problem, look in the sites TECH FACTS section and do some reading, information there might help lead you in the right direction. <br>Chime in guys If you have any other ideas...just a stab here
phox_mulder Oct 28, 2002 09:46 PM
APPS?<br><br><br>phox
Oct 28, 2002 09:56 PM
[quote author=phox_mulder link=board=4;threadid=6366;start=0#58679 date=1035863209]<br>APPS?<br>phox<br>[/quote]<br><br>Good call Phox, look in the Tech Facts section Tony for a APPS reset procedure, real simple to do and may just well cure it.
admin Oct 29, 2002 07:49 AM
Here's the link:<br><br>APPS Reset Procedure
tonyjsan Oct 29, 2002 08:45 AM
Thanks for the suggestions it is much appreciated, the truck is still under warranty and is at the dealer now, I will present these ideas to the dealer.<br><br>Thanks,<br><br>Tonyjsan
ruben Jun 15, 2003 11:28 PM
We had the same problem, surging....after three attempts, <br>the service mechanics at the dodge dealer reprogrammed<br>the computer chip. They tried to charge me $200.00. but<br>after arguing with them they decided that the reprogramming<br>fell under the ecm guides, something about exhaust regulations...anyway that fixed that problem.
Jetpilot Jun 16, 2003 08:44 AM
MAP sensor.....
HeberRam Jun 16, 2003 11:08 AM
10-4 , Change Map sensor &amp; clean the IAT sensor...That will be &quot;no charge sir&quot;. ::) ::)<br><br>Steve
drecu Jun 16, 2003 12:58 PM
[quote author=tonyjsan link=board=4;threadid=6366;start=0#58673 date=1035862667]<br>HELP !<br><br> I have had the truck to the dealer 4 times this month (it's been in repair every week in Oct). The dealer has replace a turbo boost sensor and on the last visit a wire harness of some sort. After the wire harness replace it worked for about 3 days and messed up again.<br><br><br>[/quote]<br><br>Looks like the MAP's already been replaced guys, i'm thinking apps maybe a loose connector or bad apps, either that or maybe the Cam Position Sensor aka CPS.<br><br>DRecu<br>
