Would this work?
Old May 8, 2006 | 07:48 PM
wheelo90's Avatar
Would this work?
In the future of my injection pump, I see a pump mod!
I plan on turning the full power screw a couple times in, and I would like to know some things before doing it.
First off, Could I use like an awl(one of them sharp pointed tools) or a long nail to remove that darned steel collar on the screw, by putting the point where the collar is joined together?
Also, any advice on getting into the screw to turn it?
And if I decide to turn the screw, is it possible to turn the pump up to get a small "haze" at full throttle with a load on it? Or will I have to turn the smoke screw?
Also, If I turn it up some, how much will I loose Fuel Milage wise?
Thanks for your help and advice,
Wheelo
Old May 8, 2006 | 08:10 PM
Redleg's Avatar
Don't remove the lock collar without getting a pyrometer, to know when to get off the pedal. SOme have had luck popping it off by turning a nut against it. Mine seemed to have a larger weld and I needed to touch it with a grinder. Just turn it past the lock collar and you'll see haze. All you're doing is allowing it to pump more fuel when you want to. It won't affect mileage anymore than you stomping on the pedal.
Old May 9, 2006 | 10:04 AM
wheelo90's Avatar
thanks, just may have to try it this evening.
Will I get a little more power by doing this at all,
I agree that a pyrometer would be needed if I went very far with turning the screw in.
Old May 9, 2006 | 03:48 PM
I use a 1/4" drive ratchet and a 6 mm socket to adjust on the screw.
The "smoke" screw only controls the smoke puff when you step on the pedal. Use that (along with the star wheel) to tune turbo spoolup.
Old May 10, 2006 | 10:25 AM
wheelo90's Avatar
could I get a little more power by just turning the power screw on the back of the pump in some?
Thanks for telling me how to get into it to crank on it some!
Old May 10, 2006 | 07:19 PM
Yep, that's exactly what it's there for.
Old May 10, 2006 | 07:49 PM
charger 69's Avatar
I got about 3 turns on mine,didn't do anything else and the difference is considerable.
Old May 10, 2006 | 10:52 PM
flashgordon's Avatar
Just make shore you start with a pyro!
I was supriced at how hot i could get mine and its(for the moment)fairly stock
Old May 11, 2006 | 07:58 AM
ruquik's Avatar
I used a small Craftsman screw driversto pry mine off, took abouta minute to do.
Old May 12, 2006 | 10:04 AM
wheelo90's Avatar
Roughly how many degrees will you increase by turning it in a turn?
This sounds like it is very easy to tweek on!
Thanks,
Wheelo
Old May 12, 2006 | 06:42 PM
Every truck is different. If it gets too hot you can turn it down (yeah, right).
tthomass
20
Aug 19, 2005 09:35 PM
BDR2500
May 21, 2005 09:18 PM
BDR2500
Feb 20, 2005 11:21 PM
CaughtinmyGrill
29
Jan 23, 2005 12:44 PM
LanceD
May 11, 2004 07:55 PM
