wiring mysteries
I have a 1990 d250 auto. I pulled the dash to find out why my buzzer wasn't working and noticed that behind were the cargo light button Is, there is a wire marked o/d and it's taped up. There is also another of pluges that are not connected to anything and are just hanging under the dash near the pedals. One looks just like a tach plugen on my dad's 93. I'm just curious if someone swapped a harness of if there all like that. I don't think anyone swapped it since the truck only has 96 thousand miles and I'm the second one but I don't know. Thanks
There should be no O/D switch on a '90 as it has the 3 speed NON O/D 727 in it.
How do you know it only has 96,000 miles on it? Those years have the ODO that turns over at 100,000...it might have 196,000 or 296,000 on it. |
I can't answer your question specifically but it is very common for wire harnesses to have unused connectors.
(Post 3353488)
One size fits all. Not uncommon at all for manufacturers to make one harness and not use what was not installed. Saves a lot of money doing it that way. Looking at my 91 FSM, I don't see much difference between the gas and diesel versions.Very easy to just leave a wire unconnected or change the connector. A good example is roof clearance lights. Even though you don't have them doesn't mean the wire connector is not behind the left kick panel.
https://cimg6.ibsrv.net/gimg/www.die...d99891d12a.jpg
https://cimg0.ibsrv.net/gimg/www.die...21e9739666.jpg It really confuses me. Maybe it means something else. |
Originally Posted by cougar
(Post 3353505)
The gas trucks would have had the O/D then. They probably use the same harness.
Never saw a factory harness with any labels except part numbers, someone has been in there.
It looks factory to me. Those things tend to deteriorate over time or get ripped off during repairs.
Anyone know what this is? It's behind the glove box. Thanks you guys I really appreciate the comments
Originally Posted by Mun52022
(Post 3353542)
My truck has the Rear Wheel Anti Lock (RWAL) module behind the glovebox. Along with the heater box. Edwin |
[QUOTE=Angry Johnny;3353531]It looks factory to me. Those things tend to deteriorate over time or get ripped off during repairs.I have pulled apart many Dodge 1st gens, that is definitely not factory, looks like a Painless wiring or other replacement harness.
I took a quick look but I didn't see a plug like that. Here's my RWAL plug and module FYI:
https://cimg8.ibsrv.net/gimg/www.die...6dc9a3e4a2.jpg https://cimg2.ibsrv.net/gimg/www.die...366732ba44.jpg |
