wiring harness swap - Dodge Diesel - Diesel Truck Resource Forums
wiring harness swap
Thread Tools Search this Thread
Old 03-04-2018, 11:02 AM   #1
wiring harness swap
hey guys will the wiring harness from my 91.5 w 250 fit in a 1989 d 100 cab ......i mean will all the places the wiring and stuff goes thru the cab be in the right places......anyone on here done this...id like to get all the info i can before i swap cabs and run into a bunch of problems...thanks guys
Brian.B is offline   Reply With Quote
Old 03-04-2018, 12:35 PM   #2
Blue Goose's Avatar
I sure hope so...I'll be putting an '88 gasser cab on mine
Blue Goose is offline   Reply With Quote
Old 03-04-2018, 12:46 PM   #3
Quote:
The only thing I had to do to put a 92 harness in a 90 model gas truck was the rear harness going Through the firewall I had it cut a hole with A hole saw
cabtruck is offline   Reply With Quote
Old 03-11-2018, 09:38 AM   #4
im wondering if i can swap my dash and wires into the 89 cab and will the harness bolt onto the fire wall like the 91.5.....
Old 03-11-2018, 09:58 AM   #5
Blue Goose's Avatar
the main thing would be to see if the hole for the bulk head connector is the same, anything else would/should be easy
Thread Thread Starter Forum Replies Last Post
using a 92 2wd auto engine harness and dash harness in 91.5 4wd auto 1991.5 mopar 1st Gen. Ram - All Topics 2 07-10-2016 01:27 PM
Wiring harness swap question??? blakem2208 HELP! 2 02-04-2010 05:56 PM
wiring negatively switched wiring harness ?? wyododge Performance and Accessories 2nd gen only 4 01-13-2009 02:25 AM
Electrical-Front wiring harness help needed. Hummin Cummins 3rd Generation Ram - Non Drivetrain - All Years 10 03-24-2003 07:41 AM
Trailer wiring harness TPilaske Towing and Hauling / RV 8 03-13-2003 04:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2017, DieselTruckResource.com
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
