Will a stock A518 hold up to basic pump mods?
For the time being, just so the truck is mobile, my dad and i are going to rebuild my a518 with stock components until i save for the goerend converter and heavy duty internals. I am wondering if the trans will survive basic pump mods such as the fuel screw, 3200 rpm spring, star wheel etc etc. Any input? thanks
Some 518's put up with more abuse than they should be expected to survive. The weak points are the converter and flex plate. For the time being look into the TV adjustment and make sure that's all the way up so you get the best shift pressures possible on a stock set up. Fresh fluid wouldn't hurt either. You should be fine.
does anyone know if they sell that linkage for the throttle lever on the trans? i know its incredibly wrong but ive had it ziptied to a different lever because the installer moved all my bolts and parts and lost it when i had the trans out. and my father has his own special mods he does to the valve body for a shift kit so it will shift semi-firm, but otherwise just rebuilding the trans and fresh fluid for it and the transfer case.
Bookshelf
May 1, 2008 04:43 PM
Lark
18
Feb 12, 2007 06:34 PM
RDABIKE
Jun 13, 2003 11:26 AM
