Will rear shocks do anything?
So I ordered a set of rancho 5000s (5114) built for 2.5"-4" of lift for the front of my truck, but they also ordered a pair of rancho S5000s for the rear that are for 0"-4" of lift (5005). The rear shocks are original, and do not function (might as well not even have em on there.) I am contemplating whether or not to return them because they are very expensive.
I don't think the rear bounces, but will rear shocks help my ride, or help the rear tires to hook up? Thanks!
Shocks are under-appreciatted and the last thing to get replaced when they should.
Intelligent independent truckers replace ALL shocks with each tire change.
A properly functioning shock-absorber will prevent the cupping/dipping of tires.
The springs slow downward motion and the shocks retard the reflex of the springs.
If your suspension is stiff, such as a stout 4x4 or a DRW chassis-cab with over-loads, then you probably will not be able to "feel" any difference, shocks or no, but they are performing a job, none-the-less.
When i did my shock testing with and without it rode 100 times better without the shocks hooked up.. Put one on and it wasnt to bad, but it sagged to oneside a bit. Put both on and it well u know how that is!! But it did bounce some without..
My shocks were totally dead when i pulled them, you could just move them back and forth with no resistance at all. It rode like a pogo stick going down the road and would bounce around for a while after you hit a bump. I got some used rear shocks from a 99 24 valve for free and they fit so I put them in. It did stiffen up the ride a lot, but I'd rather have it this way instead of bouncy. Some weight in the back helps quite a bit.
EverydayDiesel
Aug 19, 2007 09:38 AM
