Will a np241 from a second gen bolt up directly to a Getrag? - Dodge Diesel - Diesel Truck Resource Forums
Old 02-13-2019, 10:10 PM
I know an nv4500 and a Getrag will both work with a NP205, so will either also bolt to a 29 spline np241 with no issues? What about an np271? I know the seal on an nv4500 interferes with the Getrag’s splined coupler, would anything in the getrag’s tailhousing interfere with an np241? Thanks
Bookshelf is offline
Old 02-14-2019, 08:00 AM
I guess is it would be a bolt up thing with no issues.
The 4x4 linkage mount and shifter rod would need to be address of course.
oliver foster is online now
Old 02-14-2019, 08:30 AM
The shifter is mounted to the transfer case itself right?
Old 02-14-2019, 08:56 AM
The 4x4 shifter bracket is mounted to the transmission. The shifter rod then runs to the T-cases in both Getrag and NV-4500 set ups.
Old 02-14-2019, 08:58 AM
ZAAR's Avatar
with regard to linkage, I had to cut and shorten the linkage when I had the getrag bolted up to my np205 since I had a oe 727 with my truck I use the shs adapter that handles the spline conversion.
now with regards to the np241 I would assume it be the same situation with the bolt up and youll need to relocate and shorten the required linkage and placement. otherwise test fit time
ZAAR is offline
Old 02-14-2019, 09:17 AM
Going from a 727 to a Getrag is one thing. They both have a passenger drop NP-205 T-case.
Using a Getrag with a DRIVER side NP-241 T-case will leave you with needing to move the 4x4 shifter bracket, linkage and rod to the other side of the transmission where there are no holes on the transmission it mount it up.
That is where the custom bracket, mounting and work will need to happen.
Old 02-14-2019, 09:21 AM
ZAAR's Avatar
you are right Oliver thank you for clearing that up.
ZAAR is offline
The Following User Says Thank You to ZAAR For This Useful Post:
Angry Johnny (02-16-2019)
Bigsmoke3500
03-23-2008 05:33 PM
rschaer
08-06-2007 10:02 PM
RyeThomas
07-26-2007 11:30 AM
Dodgezilla
20
06-12-2006 05:32 PM
hw101
03-16-2003 01:07 PM
Quick Reply: Will a np241 from a second gen bolt up directly to a Getrag?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
