Will a less aggressive fuel pin help in this situation?
Old Jul 16, 2010 | 09:01 AM
apwatson50's Avatar
Originally Posted by SOOT4BRAINS
I have an m3 in my stock turned up pump. Its ok but for your situation I would recommend m2. If I were tow I would want m2. I tried my buddies m5 one time for fun and holy crap!! way worse. So m3 is good, but for less smoke I vote m2. My custom pump has a custom pin, linear and very deep cut with lots of travel, thus lots of control over fuel and a stiff afc spring. Helps out a lot with smoke.
where did you get your "stiff afc spring"?
Old Jul 16, 2010 | 10:02 AM
unixcowboy's Avatar
I wound my own....
At 15 psi boost or less the pin doesn't even move - well less than 1/8" -
but at 25 psi it's 3/4 down and all the way at something under 35.
I say 'something under' because it's very hard to control the boost up there. All I'm sure of is that it's over 32 and under 35.
I'ts helped my low end smoke and with the valet on - not letting boost get thur - I can't even hit 30 psi.
And I've got my hat ground so the pin rides higher and I'm definitely not on the ramp at low boost.
Old Jul 16, 2010 | 12:16 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
I have a valet to my pin and my pin sits at it's "base circle" but I still roll smoke. I doubt it will make much change with big injectors and a cranked power screw.
Old Jul 16, 2010 | 12:38 PM
cougar's Avatar
Originally Posted by The_Head
Was wondering if a less aggressive pin would help with towing as well.
I use an M&H M2. Smoke screw all the way up and star wheel set to let it drop in the deep notch above 15psi at sea level. Smokes under heavy load at higher altitudes though.
Just pulled a 7K trailer across AK. Held 55mph except when the road was too rough. EGT never got over 1,000° even on a long hill that held me in 4th gear and 20psi boost for 2 miles. I still had reserve to pass fords.
Old Jul 16, 2010 | 12:49 PM
cougar's Avatar
I have never touched the smoke screw. I don't even know where it is, lol, I have messed with the star wheel though. I don't remember where it is now compared to where I started. Before I messed with it the truck hardly smoked at all.
I've been driving the truck tonight and have been trying to clean up the smoke from a 30 mph roll by turning it CCW 1/4 turn at a time. The cloud still remains.
Here's a question. The 13 mm bolt that the starwheel sits in... If I don't hold it while I adjust the starwheel, am I wasting my time> I turn the star wheel and the big bolt turns with it.
Under the round cap on top of the AFC is the smoke screw. The star wheel is inside the AFC housing under the spring that pushed the fuel pin diaphragm up.
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
Old Jul 16, 2010 | 12:53 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
Giles put it in there when he built it. Not sure where he gets his parts.
Old Jul 16, 2010 | 02:05 PM
The_Head's Avatar
Ok, I have been confused the whole time. I have been adjusting the smoke screw, not the star wheel. I thought that little T25 screw was the star wheel cause it looks like a star. I have not touched the actual star wheel (yet)
Old Jul 16, 2010 | 02:13 PM
JustRamIt91's Avatar
Yeah i did the same thing for about a week. When i read more about the IP in the sticky i realized the correct terms for each part. That could explain all your extra smoke...
Old Jul 16, 2010 | 05:24 PM
92roughstock's Avatar
Have you had your injectors checked? If they arent atomizing well, all the tuning in the world is useless.
Old Jul 16, 2010 | 05:29 PM
cougar's Avatar
Welcome to club You are member 8,973,481,003.
A handy tip? Loosen the smoke screw lock nut before taking the top off the AFC. I have a good grip but it wasn't that good. Once the top is off you can see to back off the smoke screw to flush on the inside. That's were you can leave it. The star wheel is a turn and try, repeat as necessary operation. Start with 2 turns ccw.
Old Jul 16, 2010 | 05:35 PM
id try 4 turns up on the starwheel....after bottoming it out.
Old Jul 16, 2010 | 05:46 PM
The smoke screw under the cap on top, all you have to do is loosen up the 13mm and get a T25 torx and bring it the little screw in the middle out as far as it will go.
the 13mm nut is just a jamnut to lock the screw itself in place so it never moves, the nut is ok to turn while you're adjusting the screw. It has nothing to do with adjustments, it's just a locknut. The torx head in the middle is the business.
Here's a picture from 1stgen545 i edited a long time ago when i was like 14.
John, DO EXACTLY THE OPPOSITE OF WHAT I SAY TO DO IN THE TOP TEXT BOX!
Old Jul 16, 2010 | 09:15 PM
raggmann's Avatar
Roughly the same issue here.
I've turned my fuel screw in 1-1/2 turns,adjusted the idle acordingly,backed the smoke screw out flush with the bottom of the AFC cover,and turned the star wheel CCW-now it's level with the top of the threaded "post" it's mounted to. I still smoke until my boost hits around 12lbs.
I've really got to push it to hit 25lbs of boost now.
I liked the power it had with the star wheel down 2 turns CW from stock (and the boost jumping to 26lbs was cool) but it's WAY too smokey for my liking. and even worse when pulling a little 4000lb trailer.
Maybe it's time for injectors,as best as I can tell mine have around 345,000km's on them.
Old Jul 17, 2010 | 09:43 AM
unixcowboy's Avatar
According to my spring scale the stock spring only requires about 10 lbs to get to full compression. It don't take much boost to get the fuel pin moving.
Old Jul 17, 2010 | 07:38 PM
The_Head's Avatar
Alright, so I put the smoke screw back to flush, but adjusted the star screw CW 1.5 turns. It helped some, but still smokes like a battleship at pearl harbor if I dump the throttle at 30 in 3rd gear.
I'm guessing the truck must really be lugging at 30 mph in 3rd gear. I have no tach though to confirm that.
