Where to get Turbo Bearings??
Originally posted by TexasHardcore
....just make sure you have a turbo shop balance the shaft/wheels.
I've rebuilt quite a few Garrett's and Triple-K's and nary a problem. Have plenty of parts for those, but the place I get those parts from doesn't do Holset.
Thanks for the P/N's, I'll call around tomorrow and see what I can get.
you don't even need to index the wheels... they aren't dynamic balanced from the factory...
just have the turbine wheel balanced and have the compressor wheel balanced, and stick 'em together however you want.
you can bolt it back together without balancing, but holset factory tolerances aren't ideal by any means... not bad, but while its apart, I'd have the stuff balanced.
Forrest
Forrest
Hope ya'll dont mind me bringing up a old thread.I saw a hx35 that said it needed a rebuild.Would that be worth getting and rebuilding or will it be to expensive.It needs new bearings and I dont know what else it needs but was wondering how much for a rebuild?
If it needs a standard rebuild (bearings, thrust collar, rings) then it's worth it. If the bearings are worn badly, they can tear up the shaft on the turbine wheel and the bearing housing as well...which would need oversized bearings and or honing of the bearing housing and grinding of the turbine wheel shaft. If either of the wheels are damaged or have hit the housings, it will most likely need new wheels...in that case...just save your money and find a better turbo.
Easy way to "balance" a wheel assembly: before tearing it down, use a marker and mark a spot on the compressor wheel, and a spot on the same side of the turbine wheel. When reassembling, line the marks back up and torque the compressor wheel down. This only works if the rotating assembly was within balancing tolerances before the rebuild.
Shaft literally ate thru the entire thrust bearing, compressor wheel was "slightly" smaller from rubbing on the housing....I was lucky the engine didn't get damaged from sucking in all that aluminum.
But rebuilding a turbo is pretty straight forward. I've done a couple of Holsets in the past for Perkins marine diesels.
I think I paid about $85 for the kit from a truck parts supply store.
Hope this helps.
Jay
Mutt68
Sep 25, 2012 12:51 PM
Mark Hodowanec
Jun 18, 2009 08:26 AM
dizzel
Aug 7, 2007 08:30 AM
