what fluid to us on tranny
So I'm gona service my 518 tomorrow I heard its better to use hydraulic fluid instead of the regular atf is this a good choice has anybody else done this if so what kind of hydraulic fluid do I use
hmmm... I've never heard of that, and there are so many different hydraulic oils...
I've heard of using hydraulic oil to THIN the atf in your powersteering if you live in extrememly cold areas.
Your dipstick should tell you what you need: Either ATF Plus or Dexron II. I run Dexron III simply cause it's the cheap stuff and Dexron II or ATF + is obsolete and have all been replaced by now.
I expect a few to chime in and argue one way or another . "Changing" your fluid only gets 4 or 5qts of the 13-15qt system anyway. Most of it is in the torque converter or elsewhere.
There is a write up in the sticky about adjusting your bands and turning up your line pressure as well
Here are some links
TV/kickdown cable adjustment:
http://dens-site.net/Dodge_CTD/Kickdown_Adjustment/
Band adjustment/line pressure adjustment:
https://www.dieseltruckresource.com/d...e-t265745.html
Here are some links
1st Generation Admin
I have heard of it, but it's not intended for a daily-driver. Hydraulic fluid is strictly for hydraulic systems (obviously) and doesn't include any friction modifier type stuff for the clutches. But then it can be amended/supplemented.
Common
06-09-2008 12:16 PM
Tommy93w350
06-26-2007 04:42 PM
icrider
09-27-2006 03:10 PM
