What to do while motor is out? (And one more ?)
Other than a good scrubbing I am wondering what recomendations you have for me to do while I have the motor out, before I swap it into its new home. It has 196,000 on it. So far my plans are oil pan gasket, rear main seal, piston lift pump, port exhaust manifold, get rid of factory trans. cooler (to be replaced by an aftermarket unit), and possibly head studs. Anything else I should look at while the motor is out? And one more question, I was reading in the sticky about a 47rh swap and I was not clear if I would need to get a new t-case or if the one bolted to my 518 will work.
Originally Posted by BAR
(Post 2679831)
Other than a good scrubbing I am wondering what recomendations you have for me to do while I have the motor out, before I swap it into its new home. It has 196,000 on it. So far my plans are oil pan gasket, rear main seal, piston lift pump, port exhaust manifold, get rid of factory trans. cooler (to be replaced by an aftermarket unit) WHY?, and possibly head studs. Anything else I should look at while the motor is out? And one more question, I was reading in the sticky about a 47rh swap and I was not clear if I would need to get a new t-case or if the one bolted to my 518 will work.
KDP and KCB. Lock tight all the case bolts and tab the dowell pin.
DOH! You beat me by this >< much Dave!
1 Attachment(s)
Originally Posted by dieselJon
(Post 2679840)
Sounds like good plans :D
Don't forget about a new head gasket !! then stud it. |
I did the KDP about 20,000 miles ago. And I was planning on a marine head gasket and studs, hopefully, head studs are so dang expensive. But probably worth it. Anyone know about the 518 t-case bolting up to a 47rh?
If it's on the stand, I'd re-seal the entire engine and look into mains and rods while the pan is off.
case bolts and dowel pin scrub it down and put some new bearings in it! hey port the head while its off too!
(Post 2679853)
To make a long story short, the 518 and 47RH overdrive units are the same for that purpose, so yes the T-case will bolt right up. And like the others said, look at the rods and mains while you got it out, you won't get an easier opportunity to check them. A full reseal is a good idea also, timing cover to block gasket, tappet cover gasket, all those hard to get to spots, etc... |
What about its new home? Clean up the bay and coat it with bed liner.
Thanks jd730, that answers my question. As far as its new home in my 88', I plan on painting the engine compartment and putting some good sound deadening insulation on the firewall before I drop the motor in.
Also make sure the oil pan is gonna last a looooong time. They are a pain to get off when the motor is in the truck.
New Cam? maybe
re seal and a good cleaning so you can paint it
