#6886
I just got done charging the battery in my truck. The radio always runs it down because I don't get to drive it enough. Last night I went to Walgreens and it didn't want to start after sitting for 5 minutes or so with the parking lights on. I think the solenoid contacts in the starter are bad because it cranks fine once it makes contact. I have a new set just lack the ambition to install them.
Edwin
Edwin
#6887
Received 1,637 Likes
How old is the battery?
#6888
It's about 2 years old. It's the incorrect size for the truck but when I bought it the parts ape said it was correct and I wasn't up to arguing. I'm hoping it will finally die so I can justify getting the right battery. It's about 3 inches shorter than the battery tray.
Edwin
Edwin
#6889
I bought a Napa tractor trailer battery, fit perfect, and 1100 cca. Been 3 or 4 years now.
No,more charging issues anymore??
#6890
I did the J hook wiper conversion on mine yesterday using 93 ford F150 wiper arms. I had to tweek them a little so they would put more pressure on the wiper. So far they seem to work ok, but
#1 the arms ride farther out from the windshield than the stock arms did, not sure if I like the look
#2 the drivers side sets perfect but on the pass. side the wiper in the full up position rubs the seal, so they are just a little longer
The next set I do I will just go to my local pick and pull and get a set I can cut the J hook off to weld to my stock arms.
#6891
nonrev (12-02-2018)
#6892
For you folks who followed along with me recently, I don't think I need to explain anything here.
#6894
Plowed the driveway and yard out with the old 1st gen.
#6897
#6898
Yeah. I had to have my neighbor drive his mini bulldozer over through the trail system that connects our properties last Friday.
He broke the snow that slid off the shop roof up into small enough blade fulls that the old 1st gen could then push off into the wood line. It was super packed, wet, heavy snow. The pile was over 4 FT high in the center, 20 wide out from the building and spanned most of the 80 Ft of the building length. The bull dozer made easy work of it.
Note the beer can in the snow pile I put there for reference. After I saw the mess, I wanted a cold beer as I brainstormed ideas on how to fix the problem. I quickly decided that shoveling it was the last option I wanted.
It dumped snow up here for the second half of November. So far Dec. has been more normal for snowfall.
I must have had the old fist gen out to plow snow 7 or 8 times already this season.
#6899
I have had Sno-Ball out once to clear about 3-4" of snow....that's it so far this winter. Brought Sno-ball into the shop last night to replace the drivers power window switch, broke over a year ago just after I replaced the power window motor and just didn't feel like going back in. Also pulled the HVAC blower motor to put a new motor on it since it seems very weak and pulling a lot of amps.....melted the connector at the switch on low! Really should do Jim's relay for the blower.
NJTman (12-07-2018)
#6900
It's alive !
The following 7 users liked this post by NJTman:
BHD (12-09-2018),
Bob L (12-08-2018),
Diesel_Dawg (12-08-2018),
edwinsmith (12-08-2018),
N. Besonderes (12-08-2018),
and 2 others liked this post.
