WH1C install done!
Old Apr 25, 2007 | 12:06 PM
Cowboy_Customs's Avatar
WH1C install done!
OK, some of u may have been following my other thread intitled "Turbo Dilema"
Well, I got the WH1C mounted and running, and I absolutly love it!! Next to my 366 spring, this is the best mod to date! The spool is intant, it sounds like a 747, and Im only hazing under load. Now I need injectors, and a different compressor housing. Im totally happy with the results, going from the stock H1C/18.5 to the WH1C/12 W/G is just an amazing difference!
Well, now for some penny pinching, and a call to HTT. According to them the stage IV kit makes the WH1C a HX-40 Hybrid capable of handling the air needs for 400HP, which is my goal BTW (W/O drugs)
Old Apr 25, 2007 | 12:18 PM
whereswaldo250's Avatar
Awesome man, that is the turbo that I will be eventually getting Glad to see that you are happy with the install
Old Apr 25, 2007 | 03:09 PM
edwinsmith's Avatar
YUP! I love mine. Don't forget to get a $6 boost controller off Ebay. With this you can tweak your boost higher than the stock WG controller allows. I have mine set to 35# and with the 12 cm housing my boost goes there almost instantly and the kick in the butt is a real nice feeling.
I don't know why you'd need a different compressor housing though. I need a better crossover pipe since mine's a non-IC I had to grind the flange off my housing to mate but I still have the small restriction in the crossover.
Try turning up the pump before you go to bigger injectors. You might get all the power you want for free.
Edwin
Old Apr 25, 2007 | 06:00 PM
Terraizer's Avatar
What does the WH1C come off of originally? Was it a bolt on swap?
Old Apr 25, 2007 | 06:04 PM
90firstgen's Avatar
The WH1C comes off the first year or two? of second gens. Also, that turbo won't support 400hp. It could probably do that on a second gen but HTT doesn't realize how much torque we make per horsepower. I would say 350hp tops give or take with that turbo and in the words of Dave, it'll be "thermonuclear" temperatures. Obviously water/meth could get you close to the 400hp mark if you were at 350 on #2 only
G1625S's Avatar
1994 Cummins Rams. It's pretty much a bolt up for an intercooled truck. The downpipe has to be moved back some to accomodate the wastegate.
Old Apr 25, 2007 | 06:06 PM
G1625S's Avatar
Originally Posted by 90firstgen
The WH1C comes off the first year or two? of second gens. Also, that turbo won't support 400hp. It could probably do that on a second gen but HTT doesn't realize how much torque we make per horsepower. I would say 350hp tops with that turbo and in the words of Dave, it'll be "thermonuclear" temperatures.
yup. I can still hit well over 1200 with my stage III and '06 intercooler. I don't think a hybrid will break 400 rwhp on a 1st gen...without a cam and headwork anyway and for that kind of coin, you might as well shove a p-pumped engine in there
Old Apr 26, 2007 | 12:25 PM
The install was a complete "plug and play" install (STUPID MANIFOLD BOLTS!)
Like Greg said, u have to move the DP back a little. So the once close fit 4" DP is now a vertually NO clearence 4"DP. I gotta get in there sometime and make sure im not goign to melt the firewall cover deal for the blower motor. The only thing not hooked up is the wastegate. I just have not had time to find a spot run the line. Besides, I dont have a ......... Boost gauge.
YET
I need a new housing do to the fact the flange was ground off or cut off for a Non-IC crossover. The IC trucks have an aluminum 90* elbow that mounts with the same clamp as the Downpipe, so, w/o that flange I keep blowing the makeshift 90* radiator hose, IC boot elbow off of the compressor housing. I have to try n get a real 90* elbow that'll work.
The WH1C's are the stock turbos on 94 & 95 second gens. The HX-35 installed from 96 on utilizes some kind of bolting to hold the compressor housing, wheras the H1C, and W, use the band clamp. The WH1C, not only uses a 12CM W/G exhaust housing, but, also have the MWE slot, AND a larger compressor wheel.
Oh yeah, my IP is maxed. I have done ALL the cheap and free stuff, I have one thing left to try, gotta weld an extension on my fuel screw. I am at the point now, I have to purchase power.
Wonder what kind of numbers Im turning?
Old Apr 26, 2007 | 12:33 PM
93beater's Avatar
so if i went to the local boneyard and found a 94 cummins, what all would i need to pull off it, and what would the instillation be like?
Old Apr 26, 2007 | 12:50 PM
7/16 open/boxed end wrench (craftsmen quick wrench rocks here)
15MM socket with a good 6 inch extension, and nuckle, for manifold bolts
10mm socket for oil drain tube bolts.
Thats the list for the H1C, sorry, add a 15 MM boxed end wrench. I Highly suggest ONLY a 6 point boxed end and u have to make em set in some kind of penitrating oil. The W/G is in the way on all 4 nuts on the manifold mounting studs.
Be sure to get a turbo drain tube gasket, RTV is only a temp solution. Mine is leaking, $80 of Amsoil synthetic on the ground. Not badly by anymeans, but dribbling.
Now on the DP stuff, im clueless on a second gen. I only needed those 3 tools right there for the entire swap. other then 12 hours of liquid wrench or the like, to soak the manifold bolts. ok, I shoudnt say bolts, they are studs.
The manifold bolts were a livid pain, but after a night in "Liquid wrench" then a 1/2 inch drive rachet they turned right off w/o one problem.
Old Apr 26, 2007 | 01:37 PM
rbrettctd's Avatar
I kept soaking mine in PBblaster. 3 nuts came out, and one of the studs completely backed out.
Old Apr 26, 2007 | 08:15 PM
dpuckett's Avatar
Dont forget the 16mm/ 5/8" and 19mm/ 3/4" wrenches to take off the oil supply hose.
DP
Old Apr 26, 2007 | 10:08 PM
haloman's Avatar
Kinda like driving a 1st gen w/o a stack. I had to Greg I hadnt brought it up in a while
Old Apr 27, 2007 | 06:17 AM
G1625S's Avatar
You know, JR (Cowboy_Customs) just stepped up to 6'' turnouts and I jusk KNOW I could talk him out of one of his old 5'' turnouts....the pressure is getting to me
Old Apr 27, 2007 | 02:00 PM
DITTO! 3 nuts and the right front stud!
Yeah I forgot the oil supply fitting!
HEHEHEHE
Now Greg, just what makes you think u have to TALK me out of a stack?? I just havent gotten down 369 to make a special delivery yet! lol
hehehe one morning you'll go outside n see a shiney new stack sitting where one once was, and an old song will play like an ol 8track. CAUSE THATS HOW LONG IT BEEN SENCE THE OL GIRL HAD SOME BLING BLING, AND BELCHED SOOT FROM A 5 INCH PIPE PROTRUDING IN A PLACE DODGE HAD NO INTENTIONS OF!!
gimime a jingle or stop up, take yer pick, there by my parking spot next to the barn Greg.
