weights
Old Aug 17, 2006 | 11:53 AM
charliex25's Avatar
weights
Just weighed my rigg and the steering , drive wheels, fithwheel rear wheels .I would like to know if In am close to what it should be ?
Steering 3,210
Drive wheels 3,870
Trailer wheels 6,120
Total 13,200
1991 stock auto Tires Michelin A/T LT 235/85 R16 120/116R Thank Youn in advance
Charliex
Old Aug 17, 2006 | 06:04 PM
cLAYH's Avatar
What exactly do you want to know? All of your weight limits are posted on the decal on the inside of your door.
Old Aug 18, 2006 | 10:39 AM
Boatnik's Avatar
The wieght of the truck sounds close but what are you asking? Are the scales right?
Old Aug 19, 2006 | 10:03 AM
charliex25's Avatar
The decal is gone thats is why I am trying to figer out what are the correct weights
Thank you,
Charliex
Old Aug 19, 2006 | 11:18 AM
cLAYH's Avatar
Its on the same decal as the serial number and build date. If its gone I'd carefully check that the dash mounted serial number decal and make sure it hasn't been tampered with. Those decals don't "fall off".
Each decal is tailored for that truck, weights will diff depending on configuration such as year, cab, wheel base, auto/stick, 2wd/4wd, etc.
Give us the stock specs on your truck and maybe someone with a similar rig can help you out.
Old Aug 19, 2006 | 08:29 PM
DBF's Avatar
DBF
Steering 3,210
Drive wheels 3,870
Total 13,200
Charliex
My 1992 D250 & 5er weighs this:
Steer 3540
Drive 4160
Trlr 5800
Total 13540
Sounds about the same, doesn't it? See sig for equipment.
Now here's the limits for my 1992 with Superduty cooler under the bed (which *does* make a difference, per DC):
Steer 4000 GAWR
Driver 5450 GAWR
Truck total 8500 GVWR
Truck & trailer together 14,000 GCWR
Regards, DBF
Haulin_in_Dixie
Apr 2, 2003 12:23 AM
redramnc
Mar 21, 2003 09:45 AM
Desert Diesel
Jan 27, 2003 06:16 PM
NWDave
Dec 3, 2002 10:50 AM
thatguy
Nov 25, 2002 01:45 PM
