Weak Blower Motor
Weak Blower Motor
For whoever posted some of the solutions to the common blower motor problems thank you. So far I have installed a new blower motor, checked voltage at motor it's getting 12v, cut hole in heater box and cleaned out the leaves, checked the cores they seem to be clean. I have the blower wired directly to the battery with a switch. Yet it still blows air like it's on low. Any other suggestions? Thanks
Before you go and tear it apart, check and make sure the motor is turning in the correct rotation.
This is an easy mistake.
Also check the air box for any obstruction, I have sucked microfiber towels and plastic bags in though the floor inlet.
Jim
Jim
The following 2 users liked this post by Jim Lane:
bigragu (07-26-2018),
edwinsmith (07-25-2018)
Awesome.
Glad I could help.
Seems when you get a part from overseas the wiring color code means nothing.
The rotation is usually indicated on the blower wheel.
Good luck on your adventures.
Jim
Glad I could help.
Jim
You are right about foreign wiring. In Mexico, they will use whatever color for whatever circuit. It is unwise to draw any conclusions by the color of the wire...Mark
This tread is a perfect example, of what makes DTR a welcome place. Lantz is obviously new to this forum with 4 posts to his credit, and because of Jim Layne’s helpful tip, Lantz is a happy guy right now. This is how I’ve always known this forum to be. There’s no way one would even think of checking rotation first, but Jim Layne did. Saved Lantz a ton of wasted time and frustration.
The following 2 users liked this post by bigragu:
nothingbutdarts (07-26-2018),
TJE (07-26-2018)
Being a long time spectator off and on here as well as other forums I fully expected the "use the search feature" line. But I got a nice welcome from you guys here that saved my bacon, thanks again!
jimbo486 (09-02-2018)
Jim Lane
04-05-2020 06:03 AM
Copenhagenjunkie
06-01-2003 04:20 PM
