Water/Methanol Injector Location ?
Old Aug 1, 2006 | 07:07 PM
  #121
BearKiller's Avatar
Thanks for all the information.
Now, can someone give me a ballpark figure on how many 700 pound Charolais steers it will take to purchase a system to meet my needs??
Thanks.
Old Aug 1, 2006 | 09:24 PM
  #122
mhuppertz's Avatar
Thanks.
Less than one!
Old Aug 1, 2006 | 09:33 PM
  #123
mhuppertz's Avatar
Since it's typically so very dry here I was thinking about using some mysters (which I already bought) before the turbo (water only) to create some very dense air and extra boost from the vaporization and then spray water/alcohol right after the IC.
I will make sure the myst going into the turbo is extremely fine as to not further damage my beat up compressor blades.
I currently max at 34psi so I am very interested in seeing the difference with w/m injection.
Thoughts?
Old Aug 1, 2006 | 11:09 PM
  #124
BearKiller's Avatar
Rather than this pre-turbo mist going directly into the turbo, could you not keep the air-filter externally saturated, so that the turbo is breathing a fog, rather than a mist??
Just a thought, as I would be among the last to actually know.
Old Aug 1, 2006 | 11:41 PM
  #125
flashgordon's Avatar
I now! a vary small swamp cooler in replace of the filter!!!
Just kidding with ya.....but the best filter(as far as filtration) was, the 50-60 oil bath air filters
if you made a water bath filter..........na that wouldn't work, the first time you step on the go peddle the woter would slosh out and solid flow of water would be way hard on the compressor fins.
Old Aug 2, 2006 | 10:22 AM
  #126
jrussell's Avatar
A swamp cooler air filter...LOL!
Swamp coolers only working in dry climates is what got me thinking about the effects of relative humidity on w/m injection. If the humidity makes a difference between a swamp cooler working or not, it seems like it would be enough to affect w/m injection too. I'm surprised more w/m guys haven't commented on this yet.
Old Aug 2, 2006 | 10:27 AM
  #127
mhuppertz's Avatar
It would matter more if heat were not in the equation, but because the compressed inlet air is hot and in motion, there is more capacity for evaporation than if the inlet air was at ambient temp. Also more dense air can hold more of a vapor load. Lower the pressure and it starts raining! None of that matters because during the compression stroke and subsequent ignition of the injected fuel all the water/meth vaporizes instantly.
example: Steam rooms are 100% humidity, but when water is poured on those hot lava rocks it still vaporizes!
Old Aug 2, 2006 | 10:31 AM
  #128
jrussell's Avatar
Originally Posted by mhuppertz
It would matter more if heat were not in the equation, but because the compressed inlet air is hot and in motion, there is more capacity for evaporation than if the inlet air was at ambient temp. None of that matters because during the compression stroke and subsequent ignition of the injected fuel all the water/meth vaporizes instantly.
Ok, that makes sense when you consider the extra heat involved. Anyone know what kind of air intake temps our trucks see (IC and/or non-IC)?
Old Aug 2, 2006 | 10:38 AM
  #129
G1625S's Avatar
I've read the outlet of the turbo on a non-ic hovers a good deal over 300 degreesF at full boogie...couple hundred lower for an IC setup....
Old Aug 2, 2006 | 11:39 AM
  #130
mhuppertz's Avatar
I believe that it's still 200deg coming out of the intercooler at max pressure. I need to measure that when I start expreimenting with mysters.
Old Aug 2, 2006 | 11:52 AM
  #131
jrussell's Avatar
Wouldn't an IC and non-IC be about the same temp at the turbo outlet?
Old Aug 2, 2006 | 01:46 PM
  #132
mhuppertz's Avatar
I said out of the IC, not turbo...
Old Aug 2, 2006 | 02:02 PM
  #133
apwatson50's Avatar
G1625S said out of the turbo would be different.
Out of the turbo would be the same, but at the intake elbow/valves would be different.
Old Aug 2, 2006 | 02:04 PM
  #134
G1625S's Avatar
Roger that. However, don't forget that the compressor on a non IC is really quite puny, so at the same level of boost, the non-ic compressor will likely make more heat, FWIW
Old Aug 2, 2006 | 03:52 PM
  #135
Thoughts?
I wouldn't do it, it will tear the blades up no matter how fine you spray it. You will also have puddling in the intercooler.
You will likely see 45 psi with the water/meth.
