Water/ Meth injection
Don't waste money on Stage I, it's for low boost trucks like PowerStrokes and 6.5 GM diesels. Get the Stage II kit.
The only downside I have experienced is having to pop the hood and refill the tank when the fun runs out.
Seriously though, it's safe if you are careful to not exceed 50% meth and also not to spray at low boost. Mine kicks in at 20 psi. Set yours up to start spraying no lower than 15 psi, you will find that you pick up about 5 psi as soon as the spray starts.
Originally Posted by charger 69
Anyone useing a Snows stage 3? Is it worth the extra money? Whats the cost of methanol in your area?
Originally Posted by PDR Performance
Stage 3 kit features a new Digital Variable Controller with a 2d map programmed into it’s microprocessor that takes both boost and exhaust gas temps into account in regulating injection. The net effect is smooth power in all engine load states with no combustion quench resulting in a true turn-on-and-forget system. The controller is dash mounted and includes read-outs for boost, exhaust gas temp, and pump output for full visibility. This feature precludes the need for boost and EGT gauges. Complete kit ready to bolt-in!
The Stage 3 is a towing setup. It's designed to keep EGT under control while getting the best water/meth "mileage". It works for playtime too, though. If your main reason for wanting water/meth is towing, then the Stage 3 is the one to buy.
For play trucks there is no need to spend the extra money for Stage 3.
Edwin, I'd still expect to see the same benefits (200 degree EGT drop and 30-40 RWHP) out of your truck. You might do even better on the HP end of it since the air on yours is hotter to begin with.
How does this make the boost 5# higher?
I can certainly see how it would add power. Could I then add more fuel?
WANT MORE MORE MORE!
Edwin
You are adding fuel by putting in the meth. However, if your EGT is under control there's no reason you can't crank up the pump more to correct that little problem.
I'll prolly get hammered for this but im not terribly impressed with snow, i preferr aqua mist if i were buying a set up. Mine comes on at 15 the second stage on at 20 and cold start inj comes on at 25, quite a ride.
