Wait to start light
Old Mar 22, 2012 | 02:24 PM
Jaybird1962's Avatar
Wait to start light
As soon as it got warm out wait to start light flashing. Checked codes with service engine light got a 23 air temperture sensor. I got a new one did not help. Wait to start light stays on then flashed when it is running. I noticed a little more black smoke when I am going down the road and give it more throttle. Checked wires and everything I could think of. Any help with this would be great. Thanks.
Old Mar 22, 2012 | 04:47 PM
user name's Avatar
Well I wont be much help on the code itself but the engine won't run any different if a sensor is wrong. The controls on the engine are 100% mechanical it will run exactly the same if you take the computer right out of the truck. That sensor likely only used for the grid heater control.
Old Mar 22, 2012 | 05:21 PM
Pacman400's Avatar
Did you change the right sensor cause there's two air temp sensors ones for the ksb and the other is for the grids.
Old Mar 22, 2012 | 05:34 PM
Changed the front one do not know how to test the ksb switch. Could it be the ksb sensor. Thanks
Old Mar 22, 2012 | 06:04 PM
Jim5870's Avatar
Mine does that because the connector is too loose. Wiggling the wires around
usually gets the light to quit flashing for a while. Been meaning to get a new connector and splice it in.
mitm
May 20, 2014 12:32 AM
jriggs_18
Jan 11, 2007 04:43 PM
loosendend
Sep 4, 2006 12:01 PM
bfarrell
Nov 30, 2005 03:23 PM
59FORD
Aug 10, 2005 08:09 AM
