Voltage Regulator
Old Dec 15, 2008 | 09:12 PM
Jim5870's Avatar
Voltage Regulator
Occasionally my charging system acts up and starts to overcharge,
when it happens it lasts for about 30 seconds then goes back to normal.
I assume I'm having a regulator issue, I have good grounding from the regulator
to the engine block and body.
Should I try the Blue Mopar regulator PN I saw in the sticky
or try the internal regulator conversion in the sticky?
The alternator is a reman unit put on two years ago and the
regulator is a std replacement from Chrysler.
Any thoughts?
Old Dec 15, 2008 | 09:21 PM
DieselSmith's Avatar
I had this problem recently, turns out it was a loose negative battery cable! I'd check as many grounds as possible, but it could be that voltage regulator as well, although I believe the internal ones are more prone to failure than the external ones.
Old Dec 16, 2008 | 01:18 PM
vwjunkie53's Avatar
If it comes to it, go with the external, its such a easy hookup. Autozone has them for around $15
Jason
Old Dec 16, 2008 | 01:25 PM
STACKED's Avatar
yeah but i bought about 3 from autozone and all of them let it overcharge, and blew my headlights. i ended up going to the scrap yard and grabbed about 5 OE ones for 5 bucks a piece. they work like a champ.
Old Dec 16, 2008 | 06:20 PM
1985cucv's Avatar
i went to napa and gave them a picture of what i needed they gave me one for a ford i believe it works great 14.6 volts at the battery.
Old Dec 16, 2008 | 11:15 PM
loch's Avatar
it doesnt have to be for our trucks, most any reg close to the same year will work.
TurboAZ
Aug 27, 2013 09:26 PM
Cooter02
Oct 18, 2004 05:20 PM
Monty
Sep 9, 2003 08:04 PM
freeloader
Mar 28, 2003 09:00 PM
hellotbone
Oct 9, 2002 02:20 PM
