Voltage irregular
Old Dec 12, 2008 | 08:50 PM
bmxpxdude's Avatar
Voltage irregular
When I start my truck in the morning the voltage has been going up and down and the lights dim with it. I just replaced the battery, does that have anything to do with it?
Old Dec 12, 2008 | 08:55 PM
921stgen's Avatar
Where do you live? If its cold its probably just your heater grids cycling until the intake reaches a certain temp. Mine does it for about 2 miles goes to work inthe mornings.
Old Dec 12, 2008 | 11:26 PM
bmxpxdude's Avatar
i live in arizona. its cold in the mornings right now but not that cold. My truck died the other dsy while i was driving also. im wondering if my battery cables are jacked?
Old Dec 12, 2008 | 11:33 PM
gear jammer 91"'s Avatar
I believe it only needs to be below about 60 degrees for your grid heater to start cycling. If it's only doing it after start up in the morning, or after the truck has sat all day, and it goes away in a couple miles, it's the grid heater. If it does it all day, I would think you have a grounding, or voltage regulator issue.
Old Dec 13, 2008 | 06:26 AM
These threads are staring kinda late this year, usually they start in September.
It's just the grid heaters cycling, totally normal. Like gear jammer said, it's only got to get below 60 degrees for them to start working.
palermo
Oct 23, 2009 08:51 AM
captrfsella
Nov 19, 2006 06:56 AM
Pistolpatty
Jul 6, 2006 10:38 PM
cmckinney
14
Mar 4, 2004 09:51 AM
garryp
Nov 8, 2003 10:51 AM
