Video
Old Nov 29, 2008 | 06:51 PM
Ezra's Avatar
Video
Old Nov 29, 2008 | 06:57 PM
Richie O's Avatar
366 Spring Chicken
Sounds like your timing is pretty advanced.
Old Nov 29, 2008 | 07:13 PM
archer39's Avatar
nice, you need to get some traction back there though. Do you have anything done to your trans?
Old Nov 29, 2008 | 07:58 PM
GasganoFJ60's Avatar
Pretty sweet
Old Nov 29, 2008 | 07:59 PM
Ezra's Avatar
Nope nothin done to the tranny..Probably living on borrowed time..trac bars would be awesome..Anybody think it spools slow for a s300?
Old Nov 29, 2008 | 08:11 PM
Alwaysworking's Avatar
alwaysonDTR
where's the timeing set?
you should shoot a vid of a non boosted take off to show how long it takes to clear the smoke.
sure seams like it spools slow
Old Nov 29, 2008 | 08:24 PM
Ezra's Avatar
I'm thinking maybe hole in intercooler boot.cause max im hitting 25lbs of boost.
Old Nov 29, 2008 | 08:27 PM
alwaysonDTR
that or the wastegate is opening at 25psi, with all that fuel it should spool fast i would think
Old Nov 29, 2008 | 08:36 PM
Ezra's Avatar
the wastegate is set at 45lbs.
Old Nov 29, 2008 | 08:40 PM
alwaysonDTR
then check for holes in the intercooler boots
Old Nov 29, 2008 | 08:43 PM
Ezra's Avatar
probably stupid.but whats the best way to check?
Old Nov 29, 2008 | 08:47 PM
alwaysonDTR
i just feel them, for weak spots or you could pull all of them and look for holes.
i've also heard about spraying brake cleaner on the hoses but i've never tried that
Old Nov 29, 2008 | 09:18 PM
archer39's Avatar
i have a adapter made from pluming supply's with that hooks onto the turbo inlet. It has a air chuck screwed into it that i pressurize the system with. Set the regulator to about 30psi and spray it all down with soapy water wand look for leaks.
also look at the intercooler for leaks.
Old Nov 29, 2008 | 11:46 PM
Ezra's Avatar
Do they carry anything at say napa I can use to make intercooler boots out of?
Old Nov 29, 2008 | 11:52 PM
alwaysonDTR
maybe but i use a coolant hose from a parker hose supplier, sapossed to have a burst pressure of 250psi, and it dont swell up like the stockers do
