Vibration damper
Thank You for Your answers. I did search with google and came up with the same results I think, the expensive balancer You say is one filled with fluid for $488. I also found one where a 6bt balancer was adapted by using a spacer and longer bolts.
The engine does shake but after some reading I came to believe it is normal for this engine, compared to the 6bt it shakes a it more. It didn't change after I had the fuel injectors rebuilt so it must be about right. I don't want to put a balancer if it is not needed, just thought it might help.
Got to thinking. Many 4 cylinder engines have a counter shaft with eccentric weights to counter the naturlal vibration of a 4 banger. One I worked on (Leyland tractor) had 2 of em.
If it doesn't have a counterweight shaft it about has to shake. If it does, the shaft might be out of time. I can't put my hands on a 4BT schematic to see if it has one or not.
It does smooth out when I give it more rpms.
You guys really care and I appreciate it, I asked this same question on another forum and could not get a single person to give Me a hand.
Thanks to all
Thanks to all
CRToney
Feb 3, 2011 06:30 PM
dodgedsl03
Jan 18, 2007 10:08 PM
